  • PRV Audio WGP22-50 2" Black 60 x 60 Waveguide 4-Bolt
CLEARANCE PRV Audio WGP22-50 2" Black 60 x 60 Waveguide 4-Bolt
PRV AudioPart # 294-2909
Model: WGP22-50
Use PRV Audio's WGP22-50 exponential horn in professional audio and DJ speakers with most 2" compression drivers. The 60° x 60° dispersion is great for filling large spaces.
  • 2" throat with 4 bolt mounting flange accepts most 2" compression drivers
  • Reinforced mounting flange supports the weight of most drivers
  • Holes near flange allow for supports for heavier drivers
  • Constructed of durable ABS plastic
We'll send you an email when PRV Audio WGP22-50 2" Black 60 x 60 Waveguide 4-Bolt is back in stock or available for preorder.
WGP22-50 exponential horn from PRV Audio provides a 60° x 60° dispersion pattern, ideal for filling large spaces while minimizing reflections. The 2" throat and 4-bolt mounting flange is compatible with most 2" compression drivers. The reinforced plastic construction keeps weight to a minimum and features holes near the mounting flange for supports when using heavier drivers.
Specifications:• Horn type: Exponential • Minimum frequency: 800 Hz • Nominal dispersion: 60° H x 60° V • Throat diameter: 2" • Mounting type: 4-bolt flange • Dimensions: 9" dia. x 11" D • Cabinet cutout: 7.25" dia.
BrandPRV Audio
ModelWGP22-50
Part Number294-2909
UPC799928734967
Weight1.3
ConstructionABS
Entry / Throat Diameter2"
Mounting Type4-Bolt
