  • PRV Audio 8MR450CF-4 Moto Series 8” Carbon Fiber Midrange Loudspeaker 4 Ohm
NEW PRV Audio 8MR450CF-4 Moto Series 8” Carbon Fiber Midrange Loudspeaker 4 Ohm
PRV AudioPart # 294-3533
Model: 8MR450CF-4
The PRV Audio 8MR450CF‑4 is an 8″ carbon-fiber midrange driver engineered for clear, powerful vocals in rugged, water-resistant environments. Ideal for outdoor systems—boats, UTVs, motorcycles—it delivers pro-grade performance with endurance under high load.
  • Water‑resistant carbon‑fiber cone ensures outdoor durability
  • Lightweight cone reduces mass and resonance for precise midrange
  • Handles 450 W RMS for loud, clean output
  • 96 dB sensitivity delivers efficient, dynamic playback
  • Kapton former and CCAW voice coil enhance thermal stability
  • Frequency response up to 10 kHz ensures vocal clarity
NEW $79.91
MSRP: $99.89
Save $19.98 (20%)
We'll send you an email when PRV Audio 8MR450CF-4 Moto Series 8” Carbon Fiber Midrange Loudspeaker 4 Ohm is back in stock or available for preorder.
Order in the next 11 hr 2 min to ship today. Details
The 8MR450CF-4 series was engineered for powersports, built with a water-resistant design to perform reliably in outdoor conditions.
Perfect for enhancing audio systems on boats, UTVs, ATVs, or motorcycles, this midrange speaker sets a new benchmark for vocal clarity in rugged environments. Crafted with premium components such as a carbon fiber cone, high-temperature voice coil, and a robust magnet motor, it delivers natural sound with impressively low midbass distortion.
  • Water resistant design with authentic PRO audio midrange performance
  • Carbon fiber cone with damping reduces moving mass and controls resonances
  • 450 Watts power handling ensures durability at high volumes
The 8MR450CF-4 achieves its precise response through a meticulously engineered carbon fiber cone, embodying PRV Audio's hallmark depth and vocal accuracy.
This advanced cone is not only visually striking but also exceptionally lightweight and rigid, offering superior damping to minimize resonant peaks. The result is a highly natural and accurate sound, with vocal reproduction that maintains clarity and detail even at demanding output levels.
Recommended Amplifier configurations and crossover points:
2 Speakers – 1x MDX1200.2 1 Ohm, Bridged both speakers in parallel
4 Speakers – 1x MDX1800.1 1 Ohm, 4 speakers in parallel
Recommended HPF using PRV Digital Signal Processor DSP when using up to 450 Watts RMS musical power
  • 125 Hz at 12 dB per octave filter Crossover / BT12
  • 115 Hz at 18 dB per octave filter Crossover / BT18
If you have a super tweeter on your system the recommended LPF is 8,000 at 18 dB per octave filter Crossover / LR18 but you may set it lower to blend in better depending on the other components in your system, or you may not use a LPF at low power to take advantage of its high frequency response.
  • Nominal Diameter: 8″ (203 mm)
  • Nominal impedance: 4 Ohm
  • Nominal Power Handling:* 225 Watts
  • Continuous Program Power (RMS):** 450 Watts
  • Max Peak Power:*** 900 Watts
  • Sensitivity 2.83V at 1m: 96 dB
  • Recommended Hi Pass Crossover For Full Power Handling: 125 Hz 12db Per Octave Crossover
  • Frequency Response: 95 – 10,000 Hz
  • Voice Coil Diameter: 1.5 (38 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Winding Depth: 10.0 mm
  • Former Material: Kapton
  • Magnetic Gap Depth: 6.0 mm
  • Frame Material: Stamped steel
  • Overall Diameter: 8.27″ (210 mm)
  • Front Mount Baffle Cutout: 7.26″ (184.5 mm)
  • Mounting Depth: 3.21″ (81.5 mm)
  • Overall Depth: 3.62″ (92 mm)
  • Net Weight: 4.63 Lbs (2.10 kg)
BrandPRV Audio
Model8MR450CF-4
Part Number294-3533
UPC810075526004
Weight5.25
Nominal Diameter8"
Power Handling (RMS)450 Watts
Power Handling (MAX)900 Watts
Frequency Response90 to 10,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)82.8Hz
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)0.15mH
Mechanical Q (Qms)23.21
Electromagnetic Q (Qes)0.73
Total Q (Qts)0.71
Compliance Equivalent Volume (Vas)0.62ft³
Mechanical Compliance of Suspension (Cms)0.244mm/N
BL Product (BL)6.06T·m
Diaphragm Mass Inc. Airload (Mms)15.16g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)227cm²
Cone MaterialCarbon Fiber
Voice Coil Wire MaterialCCA
Overall Outside Diameter8.27"
Baffle Cutout Diameter7.26"
Depth3.21"
Sealed Volume19.68ft³
Sealed F3108.5Hz
Vented Volume55.43ft³
Vented F344.04Hz
