  • PRV Audio 10MR650A Alto Series 10" Midrange Driver 8 Ohm
PRV AudioPart # 294-3168
Model: 10MR650A
The PRV Audio 10MR650A from the ALTO Series is a 10" midrange loudspeaker engineered for high-output applications requiring natural, smooth sound reproduction. It delivers robust performance suitable for multiple types of audio systems, including professional sound reinforcement and car audio systems.
  • 2.5" CCAW voice coil on polyimide former allows high power handling
  • Vented pole piece dissipates heat to minimize power compression
  • Frequency response of 80–6,500 Hz covers critical midrange frequencies
  • Shallow 3.90" mounting depth facilitates installation in tight spaces
  • Stamped steel frame provides structural integrity and reduces resonance​
PRV Audio 10W650A Alto Series 10" Pro Woofer 8 Ohm
Price: $77.91Part # 294-2725
Your Price: $85.91
MSRP: $107.39
Save $21.48 (20%)
10 In Stock
We'll send you an email when PRV Audio 10MR650A Alto Series 10" Midrange Driver 8 Ohm is back in stock or available for preorder.
PRV Audio’s Alto Series is carefully engineered and voiced to deliver natural, smooth sound while staying dynamic. To achieve superior fidelity, a specially designed composite cone smooths frequency response and reduces moving mass, boosting overall efficiency. Introducing the updated version of the 10W650A—now improved as the 10MR650A.
  • New basket design decreases mounting depth from 4.33″ to 3.90″
  • +1dB gain in low frequency output response
  • Improved vocal performance between 350 Hz and 4000 Hz
  • Extended voice coil winding enhances power handling and increases Xmax to 5.72 mm
  • Specifically developed to boost vocal output where the 10W650A lacked, without compromising midbass
All these upgrades make the 10MR650A capable of delivering high output with low distortion—an ideal choice for reproducing essential midrange frequencies in high-output sound systems. A standout addition to the Alto Series!
  • 650 Watts program RMS power delivers strong acoustical output
  • 4 Ohm impedance makes this a great option for car audio
  • Handles extreme output levels with 97 dB sensitivity
  • Voice Coil Diameter: 2.5″
The new 10MR650A from the ALTO Series offers everything you need in a midrange pro audio loudspeaker, featuring a compact and versatile design with just 3.90” of mounting depth without compromising performance.
This midrange performs well as a door speaker in car audio systems or as a low frequency driver in a two-way satellite speaker setup.
A popular combination with the 10MR650A in large systems is the WG2000Py SLIM Mids and Highs compression horn driver—using one horn driver for every two speakers, all tuned via our digital sound processor for seamless integration with the following settings:
10MR650A – High Pass Filter HPF 120 Hz at BT18 Filter to Low Pass Filter LPF 2200 Hz at BT12, following the compression driver from 1000Hz all way to 17,000Hz
Recommended system package 8x 10MR650A + 4x WG2000Py SLIM
General Specifications
  • Nominal Diameter: 10″ (254 mm)
  • Nominal impedance: 4 Ohms
  • Rated AES Power Handling (RMS): 325 Watts
  • Program Power: 650 Watts
  • Max Peak Power: 1300 Watts
  • Sensitivity 2.83V at 1m: 97.5 dB
  • Recommended Hi Pass Crossover:** 140 Hz**
  • **For Full Power Handling **12db Per Octave Crossover
  • Frequency Response at -10dB: 80 – 6,500 Hz
  • Voice Coil Diameter: 2.5″ (65.5 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Winding Depth: 16.2 mm
  • Former Material: Polymide
  • Magnetic Gap Depth: 9.5 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 10.10” (256.5 mm)
  • Front Mount Baffle Cutout: 9.20” (233.5 mm)
  • Mounting Depth: 3.90”(99 mm)
  • Overall Depth: 4.23”(107.5 mm)
  • Net Weight: 10.4 Lbs (4.7 kg)
BrandPRV Audio
Model10MR650A
Part Number294-3168
UPC619620088314
Weight12.55
Nominal Diameter10"
Power Handling (RMS)355 Watts
Power Handling (MAX)650 Watts
Frequency Response80 to 6,500Hz
Sensitivity97.3dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)64.7Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)0.44mH
Mechanical Q (Qms)14.19
Electromagnetic Q (Qes)0.48
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)1.48ft³
Mechanical Compliance of Suspension (Cms)0.19mm/N
BL Product (BL)12.29T·m
Diaphragm Mass Inc. Airload (Mms)31.86g
Maximum Linear Excursion (Xmax)5.72mm
Surface Area of Cone (Sd)394.2cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter10.1"
Baffle Cutout Diameter9.2"
Depth4.23"
Sealed Volume0.75ft³
Sealed F3111.7Hz
Vented Volume1.25ft³
Vented F366.8Hz
