  • PRV Audio WG2000Py SLIM 2" Compression Horn Driver with SLIM Horn
PRV AudioPart # 294-3512
Model: WG2000Py SLIM
Introducing the WG2000Py SLIM, a shallow mount 2" horn driver showcasing a Polyimide Pro Audio Compression Driver paired with a 2" exit WGP14-50X Slim Waveguide. Experience unparalleled upper midrange and high-frequency response with the top-of-the-line horn driver. Engineered for high sensitivity, it delivers crystal-clear, natural sound through its Polyimide diaphragm.
  • Polyimide diaphragm with large 2.0″ Voice Coil, providing dynamic output along with excellent efficiency – 107 dB Sensitivity
  • Mids & Highs 2″ Exit Driver + Shallow Horn WGP14-50X – Perfect as compression driver for car audio
  • Crystal clear natural sound with wider response from 1000 to 17,000 Hz
  • PRO Audio horn driver, able to handle 150 Watts Continuous Program Power (RMS) with music
  • Compact driver mounted on slim horn, ideal for tight spaces, increase sound output on your system with this slim solution. Great choice for custom car audio door panels
Your Price: $79.91
Save $19.98 (20%)
We'll send you an email when PRV Audio WG2000Py SLIM 2" Compression Horn Driver with SLIM Horn is back in stock or available for preorder.
With its small diameter, the driver facilitates front mounting, simplifying installation without the need to detach it from the WGP14-50X Horn. Crafted with custom doors in mind, this shallow horn driver boasts a 2.0” voice coil, enabling it to handle increased power and significantly boost output due to its low mass diaphragm.
With its specially designed Polyimide diaphragm, this driver offers durability and additional damping for unparalleled natural sound quality. This cutting-edge technology sets a new standard for high-frequency drivers, providing a wider usable bandwidth for smooth, dynamic output and exceptional efficiency. Surpassing titanium diaphragms, Polyimide diaphragms excel in playing low frequencies without shattering and offer more precise performance at high frequencies.
BrandPRV Audio
ModelWG2000Py SLIM
Part Number294-3512
UPC810075523874
Weight7.05
Diaphragm MaterialKapton / Polyimide
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)150 Watts
Impedance8Ω
