  • PRV Audio 10MR1000 PRO Pro Series 10" Midrange Speaker 8 Ohm
PRV AudioPart # 294-3508
Model: 10MR1000 PRO
PRV's Pro Series of midrange speakers is ideal for pro audio reinforcement, live sound, high-output home audio systems, and high SPL car audio applications. The 10MR1000 PRO is a 10" midrange loudspeaker engineered for high-output performance in sealed, horn loaded and vented enclosures.
  • 3" copper voice coil on fiberglass former allows high power handling
  • Die-cast aluminum frame adds structural integrity and reduces resonance
  • Optimized for small sealed, horn-loaded, and vented enclosures
  • Frequency response of 75–6,500 Hz covers critical midrange frequencies
  • Under-spider and rear venting enhance cooling for extended performance​
Your Price: $169.91
Save $42.48 (20%)
We'll send you an email when PRV Audio 10MR1000 PRO Pro Series 10" Midrange Speaker 8 Ohm is back in stock or available for preorder.
The 10MR1000 PRO is a high-power, high-output midrange from our PRO Series, built to perform in compact sealed, horn-loaded, and vented enclosures. It’s an excellent fit for various applications, including professional sound reinforcement, live audio, high-output home speaker systems, and high SPL car audio setups.
  • Delivers excellent results in 3-way systems, reproducing detailed percussion tones with high 100 dB sensitivity.
  • A premium paper cone and cloth surround provide clear, smooth response and controlled excursion at 1000 Watts RMS program power.
  • The 3” inside/outside wound copper voice coil on a fiberglass former supports strong power handling.
  • Cooling is enhanced through under-spider and rear venting, keeping the voice coil running cool during extended play.
  • Low Qts offers high damping and great performance in compact enclosures.
This professional midrange loudspeaker produces smooth, clear vocals that stand out to any listener. Its high efficiency comes from a specially lightweight cone, designed to deliver both refined midbass tones and detailed vocal reproduction.
The cast aluminum frame provides strong structural support, while the paper/glass fiber cone paired with a large 3″ voice coil maintains control at high output levels, allowing for a smooth handoff to a high frequency driver.
General Specifications
  • Nominal Diameter: 10″ (254 mm)
  • Nominal impedance: 8 Ohm
  • Nominal Power Handling: 500 Watts
  • Continuous Program Power (RMS): 1000 Watts
  • Max Peak Power: 2000 Watts
  • Sensitivity 2.83V at 1m: 100 dB
  • Recommended Hi Pass Crossover: 150 Hz
    ** **For Full Power Handling **12db Per Octave Crossover
  • Frequency Response at -10DB: 75 – 6,500 Hz
  • Voice Coil Diameter: 3″ (75 mm)
  • Voice Coil Wire: Copper
  • Voice Coil Winding Depth: 9.2 mm
  • Former Material: Glass Fiber
  • Magnetic Gap Depth: 8.0 mm
  • Frame Material: Die Cast Aluminum
  • Overall Diameter: 10.23″ (260 mm)
  • Front Mount Baffle Cutout: 9.13″ (232 mm)
  • Mounting Depth: 4.31″ (109.5 mm)
  • Overall Depth: 4.86″ (123.5 mm)
  • Net Weight: 15.65 lbs (7.1 kg)
Explore the PRV PRO Series
8MR500SEAL PRO 8" Sealed Basket Midrange Speaker 8 Ohm
10MR800 PRO 10" Midrange Speaker 8 Ohm
10MR1000 PRO 10" Midrange Speaker 8 Ohm
12MR1000 PRO 12" Midrange Speaker 8 Ohm
BrandPRV Audio
Model10MR1000 PRO
Part Number294-3508
UPC810075525564
Weight4.85
