  • Neutrik NLT8MPXX STXX Series speakON 8-Pole Male Chassis Connector Nickel
NeutrikPart # 092-346
Model: NLT8MPXX
8-pole male chassis connector, metal square G-size housing, countersunk thru holes, 1/4“ flat tabs.
The speakON STXX Series was especially designed for heavy duty amplifier-loudspeaker applications like professional touring. The extremely rugged and durable STXX Series features an all metal housing.
  • IEC 61984 certified, thus accepted as a component of equipment acc. to IEC 62368-1
  • Current rating 30 A rms
  • Extremely robust metal housing and glass reinforced V-0 material insert designed for harsh and demanding environment
  • Uses precise “Quick Lock” system
  • Compatible with complete speakON 8 pole product series
Your Price: $17.85
MSRP: $19.93
Save $2.08 (10%)
18 In Stock
We'll send you an email when Neutrik NLT8MPXX STXX Series speakON 8-Pole Male Chassis Connector Nickel is back in stock or available for preorder.
The Neutrik STXX Series
Neutrik speakON panel mount connectors are the standard chassis connectors for loudspeaker / amplifier interconnections. They feature a unique metal locking system, making contact only once fully locked. The speakON receptacles are robust, versatile and easy to terminate.
This connector is accepted within audio equipment designed according to IEC 62368-1 due to its component certification according to IEC 61984.
BrandNeutrik
ModelNLT8MPXX
Part Number092-346
UPC844632095795
Weight0.12
Circuit8-Pole
GenderMale
