  • Neutrik NE8MX6-B-T etherCON CAT6A Cable Connector Black for Cable 1.1 mm or Less
NeutrikPart # 092-1827
Model: NE8MX6-B-T
etherCON CAT6A cable connector self-termination, for insulation diameter ≤ 1.1 mm, black plating.
The set NE8MX6 consists of a cable plug carrier offering a robust metal shell, proven Neutrik chuck-type strain relief and a CAT6A compliant RJ45 plug. The set is suitable for a cable diameter range of 7 mm to 9.5 mm and wire gauge of AWG26/1 - AWG24/1 (solid) or AWG27/7 - AWG24/7 (stranded).
  • Ruggedized connector with CAT6A component compliance according to ISO/IEC 11801 and TIA/EIA 568-C.2
  • PoE++ compliant according to 802.3bt Type4
  • IP65 protected when mated with NE8FDX-P6-W or NE8FDX-Y6-W
  • Rugged latch lock system million fold proven
  • Intermateable with the existing etherCON CAT5 range
  • Unique Neutrik chuck-type strain relief
  • Does not intermate with the CAT6 chassis connectors NE8FDY-C6 and NE8FDY-C6-B
Your Price: $19.47
Save $1.23 (6%)
26 In Stock
We'll send you an email when Neutrik NE8MX6-B-T etherCON CAT6A Cable Connector Black for Cable 1.1 mm or Less is back in stock or available for preorder.
Neutrik etherCON CAT6A Cable Connectors
etherCON CAT6A cable connector for self-termination
Attention! Does not intermate with the CAT6 chassis connectors NE8FDY-C6 and NE8FDY-C6-B.
If the insulation diameter is > 1.1 mm please refer to NE8MX6-B.
BrandNeutrik
ModelNE8MX6-B-T
Part Number092-1827
Weight0.09
