  • Neutrik NE8FDV-B Neutrik etherCON D Series Panel Mount Connector Vertical PCB Black
NeutrikPart # 092-1812
Model: NE8FDV-B
Vertical PCB panel mount RJ45 receptacle, black D-shape metal flange with latch lock, max. panel thickness 4 mm, mounting screws not included.
The Neutrik NE8FDV-B is a vertical PCB panel mount RJ45 receptacle. With a D-shape black metal flange and latching lock, this connector is designed to mount to panels with a maximum thickness of 4 mm.
  • Accommodates NE8MC* or any standard RJ45 plug
  • CAT5e / Class D according to TIA/EIA 568C and ISO/IEC 11801
  • Approved latch lock system
  • Mountable from the front or rear of the panel
  • Ground-panel connection
  • PoE type 4 class 8 (100W) acc. IEEE 802.3bt
  • Does not intermate with CAT6 cable connector NE8MC6-MO and NKE6S* cables
Your Price: $6.74
Save $0.43 (6%)
106 In Stock
We'll send you an email when Neutrik NE8FDV-B Neutrik etherCON D Series Panel Mount Connector Vertical PCB Black is back in stock or available for preorder.
The Neutrik etherCON® D Series
The etherCON Series is a ruggedized and lockable RJ45 connector system, optimized for pro audio, video and lightning network applications. The chassis connectors are shaped to fit into standardized panels out of the entertainment industry.
The D-Series offers the most rugged design of the etherCON series and is perfectly suitable for panel mount and the installer market.
Attention! Does not intermate with CAT6 cable connector NE8MC6-MO and NKE6S* cables.
BrandNeutrik
ModelNE8FDV-B
Part Number092-1812
UPC848864019635
Weight0.03
