Neutrik NC5FXX-BAG XX Series 5 Pin Female Cable Connector Black/Silver
Five-pole female XLR cable connector with black metal housing and silver contacts.
The XX Series next generation of the globally recognized standard for XLR cable connectors. As the successor to the X series, it introduces multiple new features that increase reliability, simplify assembly, and enhance both contact integrity and cable strain relief.
- Unique cage design of female contact for low contact resistance and high integrity
- Female contact incorporates a solder barrier to prevent solder running into the contact mating area
- Female connector with improved solid metal latch which is larger and easier to handle
- Neutrik chuck-style strain relief prevents breakage
- Additional ground spring contacts for better shell ground continuity
- Improved chuck type strain relief provides higher pull-out force and makes assembly easier and faster
- Colored rings available for coding or identification
We'll send you an email when Neutrik NC5FXX-BAG XX Series 5 Pin Female Cable Connector Black/Silver is back in stock or available for preorder.
