  • Neutrik NC5FXX-B 5-Pin XX Series XLR Female Cable Connector Black Metal Housing with Gold Contacts
NeutrikPart # 092-3231
Model: NC5FXX-B
Five-pole female XLR cable connector with black metal housing and gold contacts.
The XX Series next generation of the globally recognized standard for XLR cable connectors. As the successor to the X series, it introduces multiple new features that increase reliability, simplify assembly, and enhance both contact integrity and cable strain relief.
  • Unique cage design of female contact for low contact resistance and high integrity
  • Female contact incorporates a solder barrier to prevent solder running into the contact mating area
  • Female connector with improved solid metal latch which is larger and easier to handle
  • Neutrik chuck-style strain relief prevents breakage
  • Additional ground spring contacts for better shell ground continuity
  • Improved chuck type strain relief provides higher pull-out force and makes assembly easier and faster
  • Colored rings available for coding or identification
Your Price: $9.99
MSRP: $10.62
Save $0.63 (6%)
73 In Stock
We'll send you an email when Neutrik NC5FXX-B 5-Pin XX Series XLR Female Cable Connector Black Metal Housing with Gold Contacts is back in stock or available for preorder.
Order in the next 0 hr 33 min to ship today. Details
The Neutrik XX Series
The next generation of the globally recognized standard for XLR cable connectors. As the successor to the X series, it introduces multiple new features that increase reliability, simplify assembly, and enhance both contact integrity and cable strain relief.
  • Boot with polyurethane gland gives high protection to cable bending stresses
  • Sleek and ergonomic design - valuable and handy
  • Rugged zinc diecast shell, long-lasting and dependable
  • Internal thread on shell is well protected against any damage
Colored Coding Rings
Every connector in the XX Series comes with a subtle, removable plastic ring on it. Remove that ring and replace it with one of the ten different colors available to give your cable a quick an easy way to ID it. Use colors to mark cable length, signal source, destination, purpose, or anything else you can imagine.
Color coding rings sold separately.
BrandNeutrik
ModelNC5FXX-B
Part Number092-3231
Weight0.1
Conductors5-Pin
GenderFemale
Mounting TypeCable Mount
