  • Neutrik NC3MRX RX Series XLR Connector 90 Degree Right Angle Male Nickel
NeutrikPart # 092-025
Model: NC3MRX
Three-pole right angle male XLR cable connector with nickel housing and silver contacts.
The RX Series is the right angle version of the XX cable connector series. The successor of the RC series offers several new features which make it more reliable, easier to assemble and improves contact integrity as well cable strain relief.
The RX Series is the right angle version of the XX cable connector series. 3 pole right angle male cable connector, nickel housing, and silver contacts.
  • Extra slim right-angle connector
  • 5 selectable cable outlet positions
  • Male connector with improved locking recess without "window" increases durability
  • Improved chuck type strain relief provides higher pull-out force and makes assembly easy and fast
  • Boot with polyurethane gland gives high protection to cable bending stresses
  • Sleek and ergonomic design - valuable and handy
  • Colored rings available for coding or identification
Neutrik NC3MXX XX Series Male XLR Connector Nickel
Price: $3.34Part # 092-307
See all items in XLR Connectors
Your Price: $10.37
MSRP: $11.03
Save $0.66 (6%)
59 In Stock
We'll send you an email when Neutrik NC3MRX RX Series XLR Connector 90 Degree Right Angle Male Nickel is back in stock or available for preorder.
The Neutrik RX Series
  • 7 selectable cable outlet positions
  • Male connector with improved locking recess without "window", more stringent housing increases durability
  • Improved chuck type strain relief provides higher pull-out force and makes assembly easier and faster
  • Colored rings and boots available for coding or identification
Colored Coding Rings
Every connector in the RX Series comes with a subtle, removable plastic ring on it. Remove that ring and replace it with one of the ten different colors available to give your cable a quick an easy way to ID it. Use colors to mark cable length, signal source, destination, purpose, or anything else you can imagine.
Color coding rings sold separately.
BrandNeutrik
ModelNC3MRX
Part Number092-025
Weight0.12
Conductors3-Pin
GenderMale
Mounting TypeCable Mount
