  • Neutrik NC3FDXX-TOP xlrCon 3-Pin Female Airtight Front Mount Recepticle UV Rated with Cap
CLEARANCE Neutrik NC3FDXX-TOP xlrCon 3-Pin Female Airtight Front Mount Recepticle UV Rated with Cap
NeutrikPart # 092-2233
Model: NC3FDXX-TOP
The xlrCON TOP airtight chassis connector represents a pinnacle in connectivity solutions, specifically designed for demanding outdoor applications and extreme environmental conditions. As a distinguished member of the xlrCON product group within the premium signal line, this connector is engineered to deliver exceptional performance, making it the ideal choice for professionals who seek unwavering reliability.
  • IP65 & IP66 rating to protect from water and dust ingress (even in unmated and open sealing cap condition)
  • Corrosion resistance (Salt spray test 1440h)
  • UV protection (F1 housing, F2(UV) sealing) prevents it from drying out and cracking
  • Airtightness for production line tests to ensure TRUE OUTDOOR PROTECTION on devices
  • ESD protection up to 2 kV
See all items in XLR Connectors
CLEARANCE $9.69
MSRP: $11.30
Save $1.61 (14%)
13 In Stock
We'll send you an email when Neutrik NC3FDXX-TOP xlrCon 3-Pin Female Airtight Front Mount Recepticle UV Rated with Cap is back in stock or available for preorder.
Take the Show Outside
Engineered with an extensive array of protective features, the xlrCON TOP airtight ensures that your connections remain secure, even under the most challenging circumstances. You can trust its advanced design to meet the stringent requirements often associated with outdoor environments—whether it's heavy rain, high humidity, or varying temperatures, this connector is built to withstand it all.
By choosing the xlrCON TOP airtight, you are investing in true outdoor protection. This outstanding chassis connector from NEUTRIK not only meets but exceeds the expectations of industry standards. Let this innovation be your steadfast link to the future of connectivity, giving you the confidence to tackle
Make sure when you take the show outside you use Neutrik xlrCON sockets to make sure the show goes on rain-or-shine.
BrandNeutrik
ModelNC3FDXX-TOP
Part Number092-2233
UPC7613187021244
Weight0.06
Conductors3-Pin
GenderFemale
