  • Klipsch PSM-525-T Full-Range 5.25” Indoor/Outdoor Professional Surface Mount Speaker Black
KlipschPart # 247-2060
Model: PSM-525-T Black
The Klipsch PSM-525-T is a professional 5.25" surface-mount speaker designed for both indoor and outdoor use. Its rugged construction, IPX6 rating, and patented design make it ideal for commercial and distributed audio systems.
  • Patent-pending Tractrix® Hyperfold Port provides “more bass, less space” for a compact but powerful performance
  • 1" titanium compression driver provides clear, wide dispersion of high frequencies
  • IPX6 rating protects against water and dust for reliable outdoor performance
  • Multi-tap transformer allows for 70/100 V distributed systems with an 8Ω bypass for flexibility
  • Set screws on the grille maintain secure placement
  • Phoenix connector simplifies wire connections for installer convenience
  • Paintable, rust-proof aluminum grille blends seamlessly into any décor
Polk Audio Atrium 5 Outdoor Loudspeaker with 5" Woofer Pair
Price: $349.00Part # 243-624
See all items in Outdoor Speakers
Your Price: $289.99
We'll send you an email when Klipsch PSM-525-T Full-Range 5.25” Indoor/Outdoor Professional Surface Mount Speaker Black is back in stock or available for preorder.
Professional Surface Mount Speakers
The updated Professional Surface Mount speaker line now features the newly developed Tractrix Hyperfold Port. This design innovation allows for stronger bass output while also broadening dispersion, all from a more compact enclosure. The result is a system that delivers greater low-frequency performance and wider sound coverage without requiring a larger cabinet.
IPX6 Waterproof Protection
Ready for use in commercial environments both indoor and outdoor.
All-New Tractrix Hyperfold Port
We’re introducing the all-new patented Tractrix Hyperfold Port, designed with a proprietary five-step folded structure to extend port length for maximum bass power. The increased airflow eliminates chuffing and port noise while also providing a broader dispersion pattern for greater coverage.
Paintable UV-Resistant ABS Enclosure
These professional surface mount speakers are designed for flexibility, featuring rustproof grilles that can be painted to match any project color.
Multiple Tap Settings & Phoenix Connector
These speakers come equipped with a multi-tap transformer for use in 70 or 100 volt systems. For installations that don’t need a transformer, a bypass position allows standard 8 ohm operation. The PSM Series also features a phoenix connector for fast, straightforward wiring.
Set Screws on Grille
The included set screws on each grille provide a firm connection between the speaker and grille, keeping them securely attached. This design prevents the grilles from coming loose, even in challenging or demanding environments.
1" Titanium Compression Driver
Klipsch stands apart with its 1" titanium-loaded floating driver bridge featuring a wide dispersion phase plug. Combined with patented Mumps technology, these professional surface mount speakers deliver broad, even coverage and consistent acoustic energy across any space.
PSM-450-T
PSM-525-T
PSM-650-T
PSM-800-T
Frequency Response
60Hz-20kHz +/- 4dB, 50Hz -10dB
58Hz-20kHz +/- 4dB, 48Hz -10dB
56Hz-20kHz +/- 4dB, 46Hz -10dB
52Hz-20kHz +/- 4dB, 44Hz -10dB
Power Handling50 watts (14.6V) 58Hz-10kHz (200 watts peak)
65 watts (16.7V) 55Hz-10kHz (260 watts peak)
80 watts (19V) 50Hz-10kHz
(320 watts peak)
100 watts (21V) 50Hz-10kHz (400 watts peak)
Calc. Max. Cont. Output102dB104dB106dB
109dB
Sensitivity88dB89dB90dB
92dB
Coverage90° +/- 40° 1kHz-20kHz
100° +/- 20° 1kHz-20kHz
100° +/- 20° 900Hz-20kHz
Directivity Index7dB +/- 3dB 800Hz-20kHz
7dB +/- 1.5dB 1kHz-20kHz
7dB +/- 1.5dB 800Hz-20kHz
Nominal Impedance8 ohms 4.3 ohms at 185Hz minimum
8 ohms 4.3 ohms at 175Hz minimum
8 ohms 4.5 ohms at 160Hz minimum
8 ohms 4.2 ohms at 150Hz minimum
Acoustic Crossover2kHz2kHz
2kHz
2kHz
Transducers4.5” woofer
1” titanium compression driver, on a K-1500M horn/tweeter bridge
5.25” woofer
1” titanium compression driver, on a K-1200M horn/tweeter bridge
6.5” woofer
8” woofer
Enclosure MaterialAll Weather ABS Plastic, Paintable
IP RatingIPX6
IPX6
IPX6
IPX6
Enclosure TuningVented via 3 folded Tractrix ports
Input Connectors4 pin euro block
4 pin euro block
4 pin euro block
4 pin euro block
Transformer Taps70V: 15W, 7.5W, 3.8W, 1.9W
100V: 15W, 7.5W, 3.8W
Bypass position: 8 ohms nominal
70V: 30W, 15W, 7.5W, 3.8W
100V: 30W, 7.5W, 3.8W
70V: 60W, 30W, 15W,7.5W
100V: 60W, 30W, 7.5W
70V: 100W, 50W, 25W,12.5W
100V: 100W, 50W, 25W
Dimensions [with Bracket]12.13” (309 mm) x 9.5” (242 mm) x 6.5” (166 mm) [8.38” (213 mm)]
12.81” (326 mm) x 10.19” (259 mm) x 7.57” (193 mm) [9.19” (234 mm)]
15.5” (394 mm) x 12” (305 mm) x 9.31” (237 mm) [11.12” (283 mm)]
Weight7.25 lbs. (3.29kg)
7.75 lbs. (3.52kg)
11.25 lbs. (5.11kg)
15.75 lbs. (7.15kg)
BrandKlipsch
ModelPSM-525-T Black
Part Number247-2060
UPC743878057720
Weight10.6
ColorBlack
Configuration2-way
Input Rating8 Ohm
Mounting StyleSurface Mount
Woofer Diameter5.25"
Special FeaturesIndoor / Outdoor-Water Resistant
