  • Jantzen 0582 12uF 800V Superior Z-Cap Crossover Capacitor
Jantzen AudioPart # 027-495
Model: 001-0582
Jantzen Audio Superior capacitors are manufactured with one thing in mind—to provide a natural, almost holographic soundstage. The result is a reliable and consistent product that facilitates the construction of high quality, precision crossovers.
  • Dimensions: 46mm x 70mm
  • A step above the Standard Z-cap, the Superior Z-cap lets the finest nuances be heard
  • Rated Voltage: 800 VDC / 630 VAC
  • Tin plated oxygen free copper leads
  • A tolerance of ±2% (on nominal value)
Your Price: $49.06
Save $14.93 (23%)
We'll send you an email when Jantzen 0582 12uF 800V Superior Z-Cap Crossover Capacitor is back in stock or available for preorder.
Product Features
  • Dimensions: (Ø 46mm - L: 70mm)
  • The Superior-Z Cap offers extremely high performance, but still at a reasonable price point.
  • Highly recommended for tweeters and mid-range application for high-end passive speaker crossovers and as coupling capacitors in tube and power amplifiers.
  • The Superior Z-Cap is a metalized polypropylene foil capacitor but made as special construction we call a “Super MPK Capacitor”.
  • Super MKP capacitors are made with a double lane of metalized polypropylene foil, hence a double foil construction.
  • By using special winding machines and winding techniques, two capacitors are connected in series within one capacitor housing,
  • When making this type of capacitor you therefore need 4 times the foil used in standard type metalized polypropylene foil capacitors.
  • Compared to standard type metalized polypropylene foil capacitors, the Superior Z-Cap is on a higher audiophile level, where even finest nuance improvements can be heard.
  • An extremely well made and precise MKP capacitor with a tolerance on capacitance of only +/- 2%.
Technical Data
  • Type: Non-polarized super MKP (double foil lanes)
  • Construction: Double-layer round tubular type axial leads
  • Coating: Red plastic tape wrapped black resin, sealed in an anodized aluminum tube
  • Leads: Tin plated oxygen free copper
  • Voltage rating: 800 VDC / 630 VAC from 0.47 μF to 22μF
  • Capacitance tolerance: ±2% (on nominal value)
  • Dielectric absorption factor: <0.5% @ 20℃
  • Dielectric thickness: PB=6µm
  • Self-inductance: 0 nH
  • Insulation resistance: >100.000 MΩ @ 20℃
  • Temperature coefficient: -200℃ x 10-6/℃
  • Temperature Range: -55℃ to +85℃
  • Metal layer thickness: PB=0.4µm
  • Metal layer conductivity: PB =2.5 Ω/cm2
BrandJantzen Audio
Model001-0582
Part Number027-495
UPC848864078434
Weight0.2
Capacitance12 uF
Tolerance2%
Voltage Rating800V
