  • Jantzen Audio 4.7uF 400V Cross Cap Crossover Capacitor
Jantzen AudioPart # 027-924
Model: 001-0250
Jantzen Audio Cross Caps are built from ultra-high-quality metallized film and provide superb sonic accuracy and detail for any audio application. 400 VDC rating is excellent for crossover networks, allowing the capacitors to flawlessly handle large current peaks without distortion.
  • Dimensions: 18mm x 36mm
  • Virtually free of distortion with a neutral sonic profile
Your Price: $2.83
MSRP: $3.99
Save $1.16 (29%)
29 In Stock
We'll send you an email when Jantzen Audio 4.7uF 400V Cross Cap Crossover Capacitor is back in stock or available for preorder.
Order in the next 10 hr 21 min to ship today. Details
Product Features
  • Dimensions: (Ø 18mm - L: 36mm)
  • The Cross Cap is offering a high-level of performance and quality at a very reasonable price point.
  • A great multipurpose entry-level audiophile capacitor.
  • A single foil (standard type MKP/PP foil) construction that uses a good quality aluminum and zinc based metalized polypropylene foil.
  • Available in a very wide range of capacitance values.
  • Virtually free of distortion and delivers a pleasant and rather neutral sonic profile.
Technical Data
  • Capacitor foil: Polypropylene foil metalized with Zinc (Zn) and Aluminum (Al)
  • Dielectric insulation: Polypropylene film
  • Terminal leads: Tinned 4N copper wire
  • Voltage rating: 400 VDC / 250 VAC
  • Working Temperature Range: -40C to +85C
  • Capacitance tolerance: ±5%
  • Loss factor at 1 kHz (maximum)
    • C< l µF : 5 * 104
    • C> l < 20 µF : 105
    • C> 20 µF : 105
  • Insulation resistance at 1 kHz
    • C < l µF : 5 * 104 MOhm
    • l < 20 µF : 3 * 104 MOhm
    •C > 20 µF : 104 MOhm
BrandJantzen Audio
Model001-0250
Part Number027-924
UPC844632002595
Weight0.01
Capacitance4.7 uF
Tolerance5%
Voltage Rating400V
