  • Jantzen Audio 6.8 Ohm 10 Watt Audio-Grade Superes Resistor
Jantzen AudioPart # 255-9392
Model: 002-0211
The Jantzen Audio Superes series is a line of wire wound audio resistors. It is a high-quality audio-grade series built for high-end performance, with strong heat tolerance, shock resistance, and a more affordable price point.
  • Wire wound audio-grade construction supports use in high-end audio applications
  • High temperature tolerance helps the resistors handle demanding operating conditions
  • Strong resistance to shock makes them better suited to tougher installation environments
  • ±1% resistance tolerance supports more precise part selection
  • Very high heat dissipation with a small linear temperature coefficient supports more stable performance under load
  • Flame proof wrapping adds a protective construction detail to the series
Your Price: $5.79
Save $2.20 (28%)
We'll send you an email when Jantzen Audio 6.8 Ohm 10 Watt Audio-Grade Superes Resistor is back in stock or available for preorder.
Expected back in stock any day
Jantzen Audio Superes Wire Wound Audio Resistors
Product Features
  • The Superes resistors are the highest quality wire wound audio grade resistors.
  • They feature a high temperature tolerance and are very resistant to shock.
  • These resistors have always been a staple for high-end audio manufacturers and DIY enthusiasts.
  • The Superes resistors offer high-end performance, but at an affordable price point.
  • Dimensions
  • Diameter ø: 8.5 mm / 0.33"
  • Length: 53 mm / 2.09"
  • Technical Data
  • Wire wound high-end audio resistors
  • Internal Wire Material: 0.10 - 100Ω (CuNi)
  • Leadwires: Tinplated Copper
  • Resistance tolerance: +/- 1%
  • Instant overload capacity
  • Low annual shift
    Technical Data Continued
  • Operating temperature range: -55℃~200℃
  • Resistance temperature coefficient:
    It shall be within ±300ppm/°C.(under 1Ω shall be within ±500ppm/°C)
    T.C (ppm/°C) = [(R2-R1)/R1] x [1/(T2-T)] x 10⁶
    where    R1: Resistance value at reference temperature
                     R2: Resistance value at test temp.
                     T1: reference temp (usu. 25°C)
                     T2: test temp. (about 75°C)
  • Temperature Cycle: Rated power is the value of Max load power specified at the ambient temperature of 70°C. and shall meet the functions of electrical and mechanical performance. When the ambient temperature surpasses above mentioned temperature, the value declines as per following DERATING CURVE.
BrandJantzen Audio
Model002-0211
Part Number255-9392
UPC848864082196
Weight0.01
CompositionWirewound
Power Rating10W
Resistance6.8Ω
Tolerance1%
