  • Jantzen Audio 33 Ohm 10 Watt Audio-Grade Superes Resistor
Jantzen AudioPart # 255-957
With extremely low inductance and noise, Jantzen Audio's Superes line of audiophile quality resistors are the smart choice for your next crossover or amplifier design. With a tight 1% tolerance and low annual shift, you can be sure that the Superes resistors give and maintain the value you expect.
  • Top quality resistors for high-end audio application
  • Extremely low noise and inductance lower than 0.7 µH
  • Very high heat dissipation with a small linear temperature coefficient
  • A favorite amongst high-end manufacturers and DIY enthusiasts
Your Price: $6.76
MSRP: $10.99
Save $4.23 (38%)
Quantity:Qty: 1-9 $6.76/ea
Quantity:Qty: 10+ $6.08/ea
10 In Stock
We'll send you an email when Jantzen Audio 33 Ohm 10 Watt Audio-Grade Superes Resistor is back in stock or available for preorder.
Order in the next 15 hr 46 min to ship today. Details
Jantzen Audio's Superes premium resistors are ideal for use in high-end passive crossover networks. These resistors give you the sound you expect from audiophile quality resistors without the high cost. The low noise and minimal inductance design will pass audio signals without any noticeable coloration making them perfect for use in high frequency circuits. With a tight 1% tolerance, you can be sure that you get exactly the value you anticipate. Superes audio-grade resistors are the smart choice for your next speaker project.
• Resistance: 33.0 ohms
• Power handling: 10 watts
• Tolerance: ±1%
• Temperature range: -55° C to 200° C (-67° F to 392° F)
• Dimensions: 8 mm dia. x 54 mm L
• Lead length: 35 mm
BrandJantzen Audio
Part Number255-957
UPC848864056142
CompositionLow-Inductive Wirewound
Power Rating10W
Resistance33Ω
Tolerance1%
