  • Hypex Direct PreAmplifier Faceplate Silver, Knobs Included
Hypex DirectPart # 221-039
Model: H08U007664
The Hypex Direct PreAmplifier Faceplate Silver is an upgrade for compatible Hypex Direct preamplifier kits. Its silver, logo-free design gives your preamp a cleaner, more understated look while maintaining a durable aluminum construction.
  • Silver finish for a bold, elegant appearance
  • Logo-free design for a more understated front panel
  • High-grade aluminum construction
  • Direct replacement for the original supplied faceplate
  • Hassle-free installation
  • Replacement silver knobs included
Hypex Direct Nilai500 Mono Faceplate Silver Pair
Price: $95.40Part # 221-035
See all items in Audio Amplifier Boards & Modules
Your Price: $114.60
Out of Stock
We'll send you an email when Hypex Direct PreAmplifier Faceplate Silver, Knobs Included is back in stock or available for preorder.
Special Order Item Ships in 14-21 Days
Refresh the appearance of your Hypex Direct amplifier kit with Hypex's premium Silver Faceplate without the HD logo engraving, created to deliver a clean and sophisticated visual upgrade. Carefully crafted with precision and attention to detail, this faceplate is an ideal choice for anyone looking to personalize the look of their Hypex Direct preamplifier kit.
This faceplate features a silver finish that gives your amplifier a more refined appearance. Constructed from durable, high-grade aluminum, it is designed for long-term use. Its solid construction helps it withstand regular handling while preserving its clean, pristine finish.
Easy Install
Created for straightforward installation, the Silver Faceplate can be swapped easily with the original included faceplate. Remove the existing faceplate and front PCB, secure the front PCB to the replacement faceplate, and then install the new faceplate on your Hypex Direct preamplifier kit.
Go beyond the standard look. Upgrade your preamplifier with this Silver Faceplate and enjoy a refined combination of style, function, and sound quality. Give your audio system a distinctive appearance and let your preamplifier stand out on the outside as impressively as it performs on the inside.
Note:
This faceplate includes silver knobs.
BrandHypex Direct
ModelH08U007664
Part Number221-039
UPC848864083810
Weight1
