  • HiVi M6N-B 6" Damped Aluminum/Magnesium Cone Woofer
HiViPart # 297-488
Model: M6N-B
A shielded magnet structure allows the HiVi M6N-B to be incorporated easily into audio/video speaker applications.
  • Symmetrical Motor Drive (SMD) reduces distortion
  • Advanced magnesium/aluminum alloy cone provides optimal stiffness and damping
  • Hi-temp voice coil and former for high power handling
  • Magnetically shielded
  • Dynamic, accurate performance
Your Price: $28.98
Save $11.01 (28%)
We'll send you an email when HiVi M6N-B 6" Damped Aluminum/Magnesium Cone Woofer is back in stock or available for preorder.
Order in the next 5 hr 31 min to ship today. Details
A shielded magnet structure allows the HiVi M6N-B to be incorporated easily into audio/video speaker applications. The driver may be used in a small closed box as a midrange unit in a 3-way system and the good extension (50 Hz) in a vented enclosure allows for use in a 2-way, two-driver or MTM configured system.
BrandHiVi
ModelM6N-B
Part Number297-488
UPC848864070643
Weight4.4
Nominal Diameter6"
Bolt Circle Diameter6.65
Power Handling (RMS)45 Watts
Power Handling (MAX)90 Watts
Frequency Response46 to 8,000Hz
Sensitivity89dB 2.83V/1m
Voice Coil Diameter0.98"
Resonant Frequency (Fs)46Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)4.69
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.77ft³
Mechanical Compliance of Suspension (Cms)0.871mm/N
BL Product (BL)7.8T·m
Diaphragm Mass Inc. Airload (Mms)13.6g
Maximum Linear Excursion (Xmax)4.3mm
Surface Area of Cone (Sd)133cm²
Voice Coil Wire MaterialCCA
Overall Outside Diameter7"
Baffle Cutout Diameter5.313"
Depth4.0625"
Sealed Volume0.38ft³
Sealed F366.6Hz
Vented Volume0.75ft³
Vented F345.8Hz
