  • Gemini GHSI-W525BT-PR-WHT 5.25" Outdoor Bluetooth Speaker Pair White
NEW Gemini GHSI-W525BT-PR-WHT 5.25" Outdoor Bluetooth Speaker Pair White
GeminiPart # 235-111
Model: GHSI-W525BT-PR-WHT
The Gemini Sound GHSI-W525BT-PR-WHT is a pair of 5.25" Bluetooth-enabled outdoor speakers designed to deliver robust audio performance in outdoor environments. Featuring IP44 weather resistance, these speakers are suitable for patios, decks, and poolside areas. With a peak power output of 150 watts, they provide clear and dynamic sound for your outdoor gatherings.
  • IP44 weather-resistant design for reliable outdoor use
  • Bluetooth 4.1 connectivity for seamless wireless streaming
  • Includes one active and one passive speaker
  • Adjustable mounting brackets for diverse setup options
  • Remote control included for convenient operation​
  • Rust-free metal grille protects driver from dust and pests
  • Daisy-chain up to 16 speakers together using AUX cables
NEW $149.95
We'll send you an email when Gemini GHSI-W525BT-PR-WHT 5.25" Outdoor Bluetooth Speaker Pair White is back in stock or available for preorder.
150-Watts Peak Power
Each speaker features a 5.25" woofer and 0.75" tweeter for clear, well-balanced audio.
Waterproof IP44
All-season audio performance offers immersive sound year-round, no matter the climate or weather conditions.
Quick Setup
User-friendly mounting system and connections allow for quick, hassle-free installation, saving time and effort.
Stay Connected
Simple Bluetooth pairing with a built-in LED status light.
Withstand Any Conditions
Delivers consistent audio performance no matter the weather or environment.
Expand your Stereo
Connect multiple wall-mounted speakers using 3.5mm AUX jacks to create immersive surround sound.
Wireless Remote Included
Easily manage audio playback and settings remotely for added convenience.
Multi-Stereo Orientation
Adjusts position to suit different placements, delivering immersion and versatility.
  • Active/Passive: 1 Active, 1 Passive: This speaker duo, comprising an active master and a passive companion, simplifies setup and ensures consistent quality across your outdoor space. Ideal for a surround sound feel in outdoor settings, they effortlessly become an integral part of your outdoor wall mount speakers setup or a discrete yet powerful outdoor speaker wall mount system.
  • Amplifier Type: Class D: With a Class D amplifier, these speakers offer a compact, energy-efficient solution to outdoor audio without sacrificing sound quality. The amplifier's design is suited for prolonged use, ideal for outdoor powered speakers that fill your space with sound without draining energy resources.
  • LF and HF Driver Sizes: 5.25" & .75" In Each Speaker: The 5.25” LF and .75” HF drivers are engineered to deliver clear and balanced sound, from the soothing low-end to the vibrant high-end frequencies. This makes them excellent choices for wireless speakers wall mount setups or outdoor bluetooth patio speakers, providing a seamless audio experience.
  • Total Peak Power: 150W: These speakers can create a robust sound field, making them ideal for environments where space and power are at a premium, from outdoor speakers for patio use to indoor wireless speaker setups.
  • Inputs and Outputs: 1/8" (Auxiliary): The inclusion of 1/8" auxiliary inputs and outputs allows for simple, direct connections to your music sources, catering to both old-school aux cable enthusiasts and those preferring a sleek, wireless look with mountable speakers.
  • Bluetooth: Bluetooth V4.1 extends beyond 30 feet, offering freedom of movement and seamless streaming. Whether it's for outdoor audio systems or as part of a home ceiling speaker system, this feature allows for a convenient and flexible listening experience.
  • Frequency Response: 45hz-20kHz: Full Spectrum Sound: The broad frequency response of 45hz-20kHz ensures that every note, from the lowest bass to the highest treble, is delivered with precision and clarity. This wide range enhances the listening experience, ensuring that your outdoor sound system captures the full emotional range of your music.
  • Max Peak SPL @ 1 Meter: An SPL of 87dB means these speakers are capable of delivering clear audio in a variety of outdoor and indoor settings, suitable for everything from an outdoor stereo speakers system to white bluetooth speakers that blend in with their surroundings.
  • Enclosure Material: The durable ABS cabinet with an aluminum grill means these speakers are both weather-resistant and stylish, perfect for weatherproof outdoor speakers that need to withstand diverse conditions.
  • Mounting Options: With included brackets, these speakers offer versatile mounting options, whether you're looking for outdoor mountable bluetooth speakers, outdoor wall speakers, or even wireless in-ceiling speakers for a minimalistic design.
  • Weatherproof Rating: An IP44 rating ensures these speakers are protected against the elements, making them a solid choice for any outside speakers waterproof setup or for wall speakers for home that might encounter the occasional splash.
  • Power Specs: The 12V/3A power spec means these speakers are designed for efficiency, ideal for outdoor settings where power conservation is essential, and they're perfect as part of an outdoor speakers set that doesn't compromise on sound quality.
BrandGemini
ModelGHSI-W525BT-PR-WHT
Part Number235-111
UPC747705008442
Unit of MeasurePairs
Weight13
ColorWhite
Configuration2-way
Mounting StyleSurface Mount
Woofer Diameter5.25"
Special FeaturesBluetooth Wireless-Water Resistant-Powered
