  • Gemini GHSI-W650BT-PR-WHT 6.5" Outdoor Bluetooth Speaker Pair White
GeminiPart # 235-115
Model: GHSI-W650BT-PR-WHT
The Gemini Sound GHSI-W650BT-PR-WHT is a pair of 6.5" Bluetooth-enabled outdoor speakers designed to deliver robust audio performance in outdoor environments. Featuring IP44 weather resistance, these speakers are suitable for patios, decks, and poolside areas. With a peak power output of 300 watts, they provide clear and dynamic sound for your outdoor gatherings.
  • IP44 weather-resistant design for reliable outdoor use
  • Bluetooth 4.1 connectivity for seamless wireless streaming
  • Includes one active and one passive speaker
  • Adjustable mounting brackets for diverse setup options
  • Remote control included for convenient operation​
  • Rust-free metal grille protects driver from dust and pests
  • Daisy-chain up to 16 speakers together using AUX cables
Dayton Audio IO65XP 80 Watt Outdoor Installation Speaker Pair White
Price: $249.99Part # 310-041
See all items in Outdoor Speakers
Your Price: $179.95
We'll send you an email when Gemini GHSI-W650BT-PR-WHT 6.5" Outdoor Bluetooth Speaker Pair White is back in stock or available for preorder.
Order in the next 6 hr 53 min to ship today. Details
300-Watts Peak Power
Each speaker features a 6.5" woofer and 1" tweeter for clear, well-balanced audio.
Waterproof IP44
All-season audio performance offers immersive sound year-round, no matter the climate or weather conditions.
Quick Setup
User-friendly mounting system and connections allow for quick, hassle-free installation, saving time and effort.
Stay Connected
Simple Bluetooth pairing with a built-in LED status light.
Withstand Any Conditions
Delivers consistent audio performance no matter the weather or environment.
Expand your Stereo
Connect multiple wall-mounted speakers using 3.5mm AUX jacks to create immersive surround sound.
Wireless Remote Included
Easily manage audio playback and settings remotely for added convenience.
Multi-Stereo Orientation
Adjusts position to suit different placements, delivering immersion and versatility.
  • Active/Passive: 1 Active, 1 Passive: This speaker set includes an active and a passive unit, making it a breeze to install our white outdoor speakers waterproof for any setting. This pairing allows for a full stereo sound with less equipment clutter, which is perfect for outdoor spaces where aesthetics are key.
  • Amplifier Type: Class D: A Class D amplifier is at the core of these speakers, delivering efficient, high-quality sound. It's the industry standard for outdoor wireless sound systems, ensuring your outdoor audio system remains crystal clear at all volumes.
  • LF & HF Driver Sizes: 6.5" & 1" each speaker: With 6.5" LF drivers and 1" HF drivers, these speakers are capable of delivering the full spectrum of sound. Whether you're looking for outdoor speakers for patio use or outdoor wall mount speakers, these will cover every note with clarity and power.
  • Total Peak Power: 300W: With 300W of peak power, these speakers provide ample sound to fill any outdoor space, making them perfect as outdoor speakers set or even as wall speakers for home, ensuring every gathering is accompanied by powerful, dynamic audio.
  • Inputs: 1/8" (Auxiliary): The inclusion of 1/8" auxiliary inputs and outputs allows for simple, versatile connections, making these speakers an excellent choice for any outdoor mountable bluetooth speakers system where ease of use is a priority.
  • Bluetooth: BT V4.1; Range >25 ft.: Equipped with Bluetooth V4.1, these speakers offer a generous connection range of over 25 ft. This makes them ideal as outdoor Bluetooth patio speakers or for any outdoor audio system where wireless convenience is desired.
  • Frequency Response: 45hz-20kHz: The frequency response range of 45Hz-20kHz ensures that from the deep lows to the highest highs, your music will be faithfully reproduced, making these speakers perfect for any outdoor stereo speakers setup.
  • Max Peak SPL @ 1 Meter: 89dB: At 89dB, the max peak SPL at 1 meter means these speakers can deliver a loud, clear sound that is ideal for outdoor use, whether as outdoor wall mount speakers bluetooth or weatherproof speakers for an expansive sound system.
  • Enclosure Material" ABS Cabinet / Aluminum Grill: The ABS cabinet and aluminum grill protect the speakers from the elements, making them a durable choice for outdoor conditions, whether you're looking for white outdoor speakers or a robust outdoor wall mount bluetooth speakers system.
  • Mounting Options: Brackets Included: These speakers come with brackets, making them easy to install as outdoor wall mount bluetooth speakers or simply placed on any flat surface, perfect for an outdoor sound system for patio enjoyment.
  • Weatherproof Rating: IP44: With an IP44 rating, these speakers are protected against water splashes and dust, making them an excellent option for waterproof outdoor speakers in any weather.
  • Power Specs 12V/3A: Operating at 12V/3A, these speakers are energy-efficient, making them a smart addition to any outdoor wireless sound system, including use as outdoor speaker wall mount or even outdoor ceiling speakers system.
BrandGemini
ModelGHSI-W650BT-PR-WHT
Part Number235-115
UPC747705008466
Unit of MeasurePairs
Weight17
ColorWhite
Configuration2-way
Mounting StyleSurface Mount
Woofer Diameter6.5"
Special FeaturesBluetooth Wireless-Water Resistant-Powered
