NEW FaitalPRO 12RS1066 12" Neodymium Professional Subwoofer 8 Ohm
The 12RS1066 is a 12″ professional loudspeaker driver designed for long‑excursion low‑frequency applications. It combines a neodymium magnetic ring system with robust thermal architecture to deliver high SPL and controlled response.
- Handles 1,000 W AES / 2,000 W maximum power for heavy duty use
- 93 dB sensitivity (1 W/1 m) enables high output with moderate amplifier power
- Neodymium ring magnet for high flux density (1.22 T) and reduced weight
- 4″ (100 mm) copper voice coil mounted on a fibreglass former supports high thermal load
- Frequency range of 45‑2,500 Hz allows deep bass and upper low‑mid coverage
- ±12.45 mm Xmax and 20.5 mm peak‑to‑peak excursion deliver robust air movement
- Made in Italy
We'll send you an email when FaitalPRO 12RS1066 12" Neodymium Professional Subwoofer 8 Ohm is back in stock or available for preorder.
