  • FaitalPRO 12RS1066 12" Neodymium Professional Subwoofer 16 Ohm
NEW FaitalPRO 12RS1066 12" Neodymium Professional Subwoofer 16 Ohm
FaitalPROPart # 294-1058
Model: 12RS1066
The 12RS1066 is a 12″ professional loudspeaker driver designed for long‑excursion low‑frequency applications. It combines a neodymium magnetic ring system with robust thermal architecture to deliver high SPL and controlled response.
  • Handles 1,000 W AES / 2,000 W maximum power for heavy duty use
  • 92 dB sensitivity (1 W/1 m) enables high output with moderate amplifier power
  • Neodymium ring magnet for high flux density (1.22 T) and reduced weight
  • 4″ (100 mm) copper voice coil mounted on a fibreglass former supports high thermal load
  • Frequency range of 45‑2,500 Hz allows deep bass and upper low‑mid coverage
  • ±12.45 mm Xmax and 20.5 mm peak‑to‑peak excursion deliver robust air movement
  • Made in Italy
NEW $583.00
We'll send you an email when FaitalPRO 12RS1066 12" Neodymium Professional Subwoofer 16 Ohm is back in stock or available for preorder.
Order in the next 5 hr 41 min to ship today. Details
The 12RS1066 brings together a high‑power rating and efficient sensitivity to serve in sound reinforcement systems that require large‑scale bass reproduction. With an AES rating of 1,000 W and max power reaching 2,000 W, the driver is built for extended dynamic use while maintaining structure and clarity. The 92 dB sensitivity ensures the unit generates strong SPL without demanding excessive amplifier power. A 4″ copper voice coil on a fiberglass former provides superior thermal resilience, while the neodymium ring magnet and aluminum demodulation ring help suppress distortion and enhance control even under heavy load. The 45‑2,500 Hz range makes this driver capable of both robust bass and upper low‑mid frequencies, offering flexibility for use in full‑range or large sub‑systems. With ±12.45 mm linear excursion and 20.5 mm peak‑to‑peak travel, the 12RS1066 moves significant air while maintaining precision. Mechanical components such as the die‑cast aluminum basket not only strengthen the structure but also contribute to lowered resonance and coloration. All of these attributes make this driver an excellent choice for professional audio systems where power, efficiency, and clarity are crucial.
BrandFaitalPRO
Model12RS1066
Part Number294-1058
UPC848864081649
Weight15.85
Nominal Diameter12"
Bolt Circle Diameter11.75
Impedance16Ω
Frequency Response45 to 2500Hz
Sensitivity92dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)45Hz
DC Resistance (Re)12Ω
Voice Coil Inductance (Le)2.5mH
Mechanical Q (Qms)11.2
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.44
Compliance Equivalent Volume (Vas)1ft³
Mechanical Compliance of Suspension (Cms)0.08mm/N
BL Product (BL)33.5T·m
Diaphragm Mass Inc. Airload (Mms)151.5g
Maximum Linear Excursion (Xmax)12.45mm
Surface Area of Cone (Sd)496cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.44"
Baffle Cutout Diameter11.10"
Depth6.95"
Sealed Volume0.241ft³
Sealed F393.9Hz
Vented Volume1.11ft³
Vented F340.79Hz
