  • Eminence Omega Pro-18A 18" Cast Frame Woofer
Eminence SpeakerPart # 290-428
Model: Omega Pro-18A
Eminence's Omega Pro-18A 18" cast frame speaker is recommended for professional audio of all types, and will provide great results as a high-power subwoofer for PA and dance systems.
  • Two-layer, 27ga. copper voice coil with Kapton® coil former
  • Vented and extended pole piece
  • Die-cast aluminum basket
  • Paper cone with cloth cone edge
  • Solid composition paper dust cap
Dayton Audio Pro 18 in. 8 Ohm Neodymium Subwoofer Odeum 18N
Price: $277.98Part # 295-644
Peavey 18" Low Rider Subwoofer Speaker
Price: $299.99Part # 294-301
Your Price: $264.99
MSRP: $331.24
Save $66.25 (20%)
8 In Stock
We'll send you an email when Eminence Omega Pro-18A 18" Cast Frame Woofer is back in stock or available for preorder.
Order in the next 7 hr 29 min to ship today. Details
The Eminence Omega Pro-18A 18" cast frame speaker is equipped with a large 4" diameter voice coil and a 109 oz. ceramic ferrite magnet with bumped back plate. The Omega Pro-18A is an ideal driver choice for vented subwoofer enclosures as well as horn loading and scoops. Made in the USA. 7-year manufacturer's warranty!
BrandEminence Speaker
ModelOmega Pro-18A
Part Number290-428
UPC876358000425
Weight28.05
Nominal Diameter18"
Power Handling (RMS)800 Watts
Power Handling (MAX)1600 Watts
Frequency Response40 to 800Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)25Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)1.67mH
Mechanical Q (Qms)8.18
Electromagnetic Q (Qes)0.32
Total Q (Qts)0.31
Compliance Equivalent Volume (Vas)19.38ft³
Mechanical Compliance of Suspension (Cms)0.29mm/N
BL Product (BL)18.8T·m
Diaphragm Mass Inc. Airload (Mms)137g
Maximum Linear Excursion (Xmax)4.8mm
Surface Area of Cone (Sd)1159cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter18"
Baffle Cutout Diameter16.56"
Depth8.15"
Sealed Volume3.5ft³
Sealed F364.5Hz
Vented Volume7ft³
Vented F332.7Hz
