  • Eminence Omega Pro-15A 15" Cast Frame Driver
Eminence SpeakerPart # 290-430
Model: Omega Pro-15A
Recommended for professional audio, the Eminence Omega Pro-15A 15" speaker is optimized for use as a woofer in vented enclosures. Also good for horn loading and scoops.
  • 4", two-layer, 27 ga. copper voice coil with Kapton® former
  • Vented and extended pole piece
  • Die-cast aluminum basket
  • Paper cone with double half-roll cloth cone edge
  • 800 watts RMS power handling
Beyma 15WR400 WR Series 15" Subwoofer 8 Ohm
Price: $229.23Part # 253-061
Your Price: $224.99
Save $56.25 (20%)
5 In Stock
We'll send you an email when Eminence Omega Pro-15A 15" Cast Frame Driver is back in stock or available for preorder.
Recommended for professional audio, the Eminence Omega Pro-15A 15" speaker is optimized for use as a woofer vented enclosures. Also good for horn loading and scoops. 4" copper voice coil, 109 oz. magnet, cast aluminum frame. The 800 watts RMS Omega Pro-15A delivers performance equal to drivers costing twice as much! Made in the USA. 7-year manufacturer's warranty!
BrandEminence Speaker
ModelOmega Pro-15A
Part Number290-430
UPC876358000418
Weight24.31
Nominal Diameter15"
Power Handling (RMS)800 Watts
Power Handling (MAX)1600 Watts
Impedance8Ω
Frequency Response51 to 1,700Hz
Sensitivity97.3dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)33Hz
DC Resistance (Re)5.28Ω
Voice Coil Inductance (Le)1.04mH
Mechanical Q (Qms)5.69
Electromagnetic Q (Qes)0.33
Total Q (Qts)0.32
Compliance Equivalent Volume (Vas)9.1ft³
Mechanical Compliance of Suspension (Cms)0.25mm/N
BL Product (BL)17.5T·m
Diaphragm Mass Inc. Airload (Mms)94g
Maximum Linear Excursion (Xmax)4.8mm
Surface Area of Cone (Sd)856.3cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter15.21"
Baffle Cutout Diameter14"
Depth6.35"
Sealed Volume2ft³
Sealed F375.5Hz
Vented Volume5ft³
Vented F344.2Hz
