  • Dayton Audio Powered Outdoor Subwoofer and 4" Compact Pendant /Landscape Speaker Bundle White
Dayton AudioPart # 310-1502
Create a complete, weather-ready outdoor sound system with the Dayton Audio WP40XTW and IOSUBP bundle, combining clear, balanced audio with deep, powerful bass in one easy-to-set-up package. The WP40XTW speakers feature a 2-way coaxial design with a 4" woofer and 3/4" tweeter, delivering crisp highs and smooth mids, all housed in sleek, IP66-rated weather-resistant ABS enclosures that work equally well indoors or out. Pairing perfectly with them, the IOSUBP subwoofer adds rich low-end punch through a high-excursion 10" woofer and features a built-in Bluetooth amplifier that powers both the sub and two additional speakers, eliminating the need for external amps or complex wiring. Simple volume and crossover controls make fine-tuning your sound quick and hassle-free, while the rugged, compact design ensures durability in patios, pools, gardens, or any outdoor living area.
  • Built-in 160 Watt Bluetooth amplifier powers the subwoofer and two additional outdoor speakers—no external amp needed
  • Weatherproof IP66-rated design is built to withstand rain, dust, and outdoor conditions
  • 10" high-excursion woofer delivers deep, powerful bass in a compact enclosure
  • Flexible Mounting: Pendant, wall, and landscape mounting options included.
  • Enhanced Audio Performance: 80–20,000 Hz frequency response with 20W RMS power handling
  • Stylish Finish: Sleek white enclosure suits any aesthetic, from modern to classic.
  • Ideal for outdoor spaces like patios, pools, gardens, and backyard setups
See all items in Outdoor Speakers
Your Price: $554.98
MSRP: $721.99
Save $167.01 (23%)
Effortless Setup
Effortless setup in minutes! Simply connect the powered subwoofer’s power cable to a nearby power outlet and use the supplied waterproof wire nuts to connect the stereo output to your favorite pair of patio speakers. You can fine-tune the crossover frequency for a smooth blend between the subwoofer and your speakers, then set the subwoofer volume to match the overall system balance. A convenient pairing button lets you easily enter Bluetooth pairing mode or disconnect a connected device with a single press.
The IOSUBP is equipped with a built-in 2.1-channel amplifier and Bluetooth 5.3, eliminating the need to run wires through walls or ceilings—making installation fast, clean, and hassle-free. And because it’s designed for open-air use, the lack of walls or physical boundaries becomes a major advantage: Bluetooth range and stability are maximized, delivering strong, uninterrupted wireless audio performance up to 30 feet from the main speaker.
Bass Radiator for Extended Bass Response
The IOSUBP’s woofer is built for serious performance, featuring a graphite poly cone, 2" 4-layer voice coil, stitched rubber surround and over 10mm of excursion for powerful low-end response. Housed in a heavy-duty down-firing sealed enclosure, it delivers deep, tight bass down to 40 Hz with 160 watts of built-in power. Despite its compact footprint, the subwoofer packs a punch, providing rich bass while blending seamlessly into any outdoor setting.
Engineered to endure the elements, the IOSUBP features an IP66-rated enclosure that shields the subwoofer and internal electronics from harsh environmental conditions, ensuring long-lasting, reliable performance. Its down-firing design offers natural protection for the woofer and controls while delivering omni-directional sound, making placement more flexible and less critical. With its rugged construction and weather-resistant build, the IOSUBP is ideal for enhancing outdoor spaces like pools, patios, gardens, and landscaped areas with deep, immersive bass.
Key Subwoofer Specifications
  • Description: 10" Indoor/Outdoor Bluetooth 2.1 Channel Powered Subwoofer
  • Woofer: 10" Polypropylene Cone
  • Frequency response: 40-300 Hz
  •  Impedance: 4 ohms
  •  Low pass filter: Variable
  •  Ingress protection rating: IP66
  • Color: Black
  • Dimensions: 12.2" x 16.5" x 16.5"
Dayton Audio 4" Compact Pendant/Landscape Speaker WP40XTB
For ultimate flexibility, the Dayton Audio pendant indoor/outdoor speaker line offers multiple installation options, including pendant mounting, wall mounting, and landscape mounting. Designed to withstand the elements, these speakers feature durable, weather-resistant ABS plastic construction, ensuring long-lasting performance in any environment. Whether you're enhancing an outdoor patio, a commercial venue, or an indoor space, Dayton Audio pendant speakers provide reliable, high-quality sound with versatile mounting configurations to suit your specific needs.
           Pendant Mount
           Surface Mount
       Landscape Mount
Pendant Mount
The Dayton Audio WP40XTW includes versatile mounting hardware designed for secure and easy installation. A specialized end cap protects the transformer tap selection and Phoenix wire connector, ensuring a clean and professional look. Additionally, an integrated eye bolt allows for safe hanging using a steel safety cable, making this speaker a reliable choice for pendant mounting in both indoor and outdoor audio setups.
Surface Mount
In addition to pendant mounting, the Dayton Audio WP40XTW features a ball joint mount for seamless vertical and horizontal axis adjustments, allowing precise positioning on walls or ceiling structures. This versatile mounting option ensures optimal sound dispersion, making it ideal for both commercial and residential audio applications. Enhance your audio setup with flexible installation options tailored to your space.
Landscape Mount
Finally, the Dayton Audio WP40XTW features a ball joint mount that securely connects to a durable landscape-style stake, ensuring robust support for outdoor in-ground installations. This innovative design provides stable positioning in gardens, yards, or landscaped areas, delivering premium audio performance while seamlessly blending into any outdoor environment. Ideal for elevating outdoor entertainment, this speaker offers dependable performance and versatile mounting options tailored for any setup.
Part Number310-1502
UPC848791011450
Weight46.99
