  • Dayton Audio DSA90-PR 3" Designer Series Aluminum Cone Passive Radiator
Dayton AudioPart # 295-542
Model: DSA90-PR
The Dayton Audio Designer Series passive radiators are excellent general-purpose passives suitable for replacement or for new construction. Built to be a perfect match for the Designer Series drivers, these passive radiators feature the same steel frame, rubber surround, and anodized aluminum cone making them visually identical.
  • Perfect match for Dayton Audio's aluminum cone Designer Series drivers
  • Allows tuning small enclosures lower than using conventional ports
  • Rear mounted screw allows easy mass adjustment for custom tuning
  • Cosmetic frame edge looks great even when surface mounted
Your Price: $16.98
Save $6.01 (26%)
We'll send you an email when Dayton Audio DSA90-PR 3" Designer Series Aluminum Cone Passive Radiator is back in stock or available for preorder.
Order in the next 1 hr 4 min to ship today. Details
The Dayton Audio Designer Series passive radiators are excellent general-purpose passives suitable for replacement or for new construction. A built-in mass disc offers a good starting point for most designs, and a convenient M5 threaded hole (screw included) allows different types of weights to be added if desired. Cosmetically and mechanically, these passives match Dayton Audio's Designer Series drives, with a black anodized aluminum cone and medium-roll rubber surround for clean excursion and long life. The possibilities with these passives are endless, from desktop two ways to portable battery powered speaker systems.
Specifications: • Fs: 43.7 Hz • Vas: 0.124 ft³ • Qms: 5.72 • Cms: 2.55 mm/N • Rms: 0.2 kg/s • Mms: 5 g • Sd: 31.2 sq. cm. • Xmax: 4 mm • Dimensions: Overall diameter: 3.63", Cutout diameter: 2.76", Depth: 0.86".
Note: Adding mass to the passive radiator will decrease Fs and increase Qms.
Tip: As a general rule, the passive radiator(s) should have at least double the displacement of air (Vd) as the active woofer(s)/subwoofer(s) in the system.
To calculate Vd: Sd x Xmax = Vd
ModelDSA90-PR
Part Number295-542
UPC848791005022
Weight0.2
Nominal Diameter3"
Bolt Circle Diameter3.27
Resonant Frequency (Fs)43.7Hz
Mechanical Q (Qms)5.72
Compliance Equivalent Volume (Vas)0.124ft³
Mechanical Compliance of Suspension (Cms)2.55mm/N
Diaphragm Mass Inc. Airload (Mms)5g
Surface Area of Cone (Sd)31.2cm²
Cone MaterialAluminum
Overall Outside Diameter3.63"
Baffle Cutout Diameter2.76"
Depth0.86"
