Dayton Audio DPR20-7.0 7 Ohm 20 Watt Precision 1% Audio Grade Resistor
- Extremely low inductance to avoid any unexpected changes to the audio signal
- Extra long 50 mm leads make these resistors ideal for use in point-to-point circuit designs
- Non-magnetic construction includes nickel-chromium internal wire with copper endcaps and leads
- Internal ceramic tube has great stability and heat dissipation for long life and reliable performance
- Nickel-chromium wiring and non-flammable coating to withstand moisture and corrosion
- Tight 1% tolerance to ensure expected and reliable operation
We'll send you an email when Dayton Audio DPR20-7.0 7 Ohm 20 Watt Precision 1% Audio Grade Resistor is back in stock or available for preorder.
