  • Dayton Audio DPR20-2.0 2 Ohm 20 Watt Precision 1% Audio Grade Resistor
Dayton AudioPart # 007-2
Model: DPR20-2
Designed for use in no compromise crossover designs, Dayton Audio's Precision 20 watt Audio Grade Resistors are ideal for use in your next high end speaker design. The extremely low inductance, non-magnetic construction, tight 1% tolerance, copper end caps, and gold plated copper leads give this high quality 2 ohm resistor the ability to provide reliable and consistent performance without any detrimental effects to the original audio signal.
  • Extremely low inductance to avoid any unexpected changes to the audio signal
  • Extra long 50 mm leads make these resistors ideal for use in point-to-point circuit designs
  • Non-magnetic construction includes nickel-chromium internal wire with copper endcaps and leads
  • Internal ceramic tube has great stability and heat dissipation for long life and reliable performance
  • Nickel-chromium wiring and non-flammable coating to withstand moisture and corrosion
  • Tight 1% tolerance to ensure expected and reliable operation
Your Price: $6.25
Save $2.74 (30%)
212 In Stock
We'll send you an email when Dayton Audio DPR20-2.0 2 Ohm 20 Watt Precision 1% Audio Grade Resistor is back in stock or available for preorder.
Dayton Audio's Precision Series Audio Grade 20 watt resistors are designed specifically for use in high-end, no compromise crossover networks. The nickel-chromium winding, a high thermal conductivity tubular ceramic core, welded construction, and completely non-magnetic components allow these resistors to pass audio signals while maintaining their original sonic character and detail. With a precision 1% tolerance, gold-plated oxygen free copper leads, and low-inductive wire wound construction, these resistors are an excellent choice for you next premium speaker design. Sold individually.
Dimensions: • 51.5 mm L x 14 mm diameter • 50 mm leads.
ModelDPR20-2
Part Number007-2
UPC848791006920
CompositionLow-Inductive Wirewound
Power Rating20W
Resistance
Tolerance1%
