  • Celestion TF1225 12" Professional Speaker 250W
CelestionPart # 294-2078
Model: TF1225
The Celestion TF1225 12" loudspeaker driver delivers high fidelity, long-term performance when used in demanding sound reinforcement applications like stage monitors, compact main speaker boxes, and larger scale PA systems.
  • 12" bass and midrange driver providing 97 dB sensitivity and 250 watts RMS power handling
  • 2.5" high temperature copper voice coil wound on a polyimide former for increased reliability
  • Optimized ceramic ferrite magnet design reduces weight
  • Double half-roll surround for greater excursion control
  • For use in 2-way or compact 3-way systems
Your Price: $119.00
MSRP: $178.50
Save $59.50 (33%)
9 In Stock
We'll send you an email when Celestion TF1225 12" Professional Speaker 250W is back in stock or available for preorder.
Order in the next 0 hr 20 min to ship today. Details
Celestion's TF1225 12" speaker boasts high power handling and excellent efficiency, thanks to its optimized 42 oz. ceramic ferrite magnet, 2.5" copper voice coil, and vented pole piece. It delivers strong, smooth response to beyond 4 kHz, and delivers a strong bass punch in any type of enclosure. The TF1225 is intended for use in 2-way or 3-way pro loudspeaker systems.
BrandCelestion
ModelTF1225
Part Number294-2078
UPC739894531153
Weight10.6
Nominal Diameter12"
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response50 to 4,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)55.6Hz
DC Resistance (Re)5.08Ω
Voice Coil Inductance (Le)0.86mH
Mechanical Q (Qms)3.11
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)2.38ft³
Mechanical Compliance of Suspension (Cms)0.17mm/N
BL Product (BL)14.32T·m
Diaphragm Mass Inc. Airload (Mms)48.52g
Surface Area of Cone (Sd)531.3cm²
Cone MaterialPaper / Kevlar
Surround MaterialCloth
Overall Outside Diameter12.17"
Baffle Cutout Diameter11.14"
Depth5.12"
Sealed Volume0.68ft³
Sealed F3119.2Hz
Vented Volume1.75ft³
Vented F362.9Hz
