  • Celestion G10 Greenback 10" 8 Ohm Guitar Speaker 30W
CelestionPart # 294-2250
Model: G10 Greenback
The Celestion G10 Greenback is a 10" steel-chassis guitar speaker developed to recapture the legendary sound of Celestion’s 1970s 10s. It pairs surprisingly meaty tone with the weighty low-end balance of a 12" speaker, along with a complex mid-range and smooth vintage top-end.
  • Meaty tone in a 10" format for fuller guitar sound from a smaller speaker
  • Weighty low-end balance of a 12" speaker for bigger sounding lows
  • Complex mid-range for richer and more expressive guitar character
  • Smooth vintage top-end for a more classic high-frequency voice
  • Adds real class in small combos for a more refined combo amp sound
  • Raunchy full-bodied tone in a 4×10 for bigger cabinet-driven impact
  • Rich low-end thump in multi-speaker configurations for more authority and punch
Your Price: $115.00
MSRP: $172.50
Save $57.50 (33%)
Only 2 In Stock
We'll send you an email when Celestion G10 Greenback 10" 8 Ohm Guitar Speaker 30W is back in stock or available for preorder.
This guitar speaker was created to bring back the legendary tone of Celestion’s 1970s 10" models, delivering a 10" speaker sound with unexpectedly full-bodied character. Though its output is modest, the G10 Greenback carries the substantial low-end presence of a 12" speaker, along with a complex midrange and a smooth vintage-style top end. In small combo amps, it adds a distinctly refined character, and in a 4×10 configuration, it produces a gritty, full-bodied tone with plenty of low-end punch.
  • Nominal diameter: 254mm / 10in
  • Power rating: 30W
  • Rated impedance: 8Ω
  • Sensitivity: 95dB
  • Chassis type: Pressed steel
  • Magnet type: Ceramic
  • Magnet weight: 0.56kg / 20oz
  • Voice coil diameter: 1.75in / 44mm
  • Voice coil material: Round copper
  • Frequency range: 95-5500Hz
  • Resonance frequency, Fs: 98Hz
  • DC resistance, Re: 6.4Ω
  • Cut-out diameter: 229mm / 9in
  • Diameter: 254mm / 10in
  • Magnet structure diameter: 124mm / 4.9in
  • Mounting hole dimensions: 6.5x8.9mm / 0.25x0.35in
  • Mounting hole PCD: 245mm / 9.6in
  • Number of mounting holes: 8
  • Chassis depth (inc gasket): 72mm / 2.83in
  • Magnet depth: 30mm / 1.17in
  • Overall depth: 102mm / 4.0in
  • Unit weight: 1.6kg / 3.5lb
Frequency Response
BrandCelestion
ModelG10 Greenback
Part Number294-2250
UPC739894564601
Weight4.9
Nominal Diameter10"
Power Handling (RMS)30 Watts
