  • Celestion G10 Greenback 10" 16 Ohm Guitar Speaker 30W
CelestionPart # 294-2252
Model: G10 Greenback
The Celestion G10 Greenback is a 10" steel-chassis guitar speaker developed to recapture the legendary sound of Celestion’s 1970s 10s. It pairs surprisingly meaty tone with the weighty low-end balance of a 12" speaker, along with a complex mid-range and smooth vintage top-end.
  • Meaty tone in a 10" format for fuller guitar sound from a smaller speaker
  • Weighty low-end balance of a 12" speaker for bigger sounding lows
  • Complex mid-range for richer and more expressive guitar character
  • Smooth vintage top-end for a more classic high-frequency voice
  • Adds real class in small combos for a more refined combo amp sound
  • Raunchy full-bodied tone in a 4×10 for bigger cabinet-driven impact
  • Rich low-end thump in multi-speaker configurations for more authority and punch
Your Price: $115.00
MSRP: $172.50
Save $57.50 (33%)
Out of Stock
We'll send you an email when Celestion G10 Greenback 10" 16 Ohm Guitar Speaker 30W is back in stock or available for preorder.
This guitar speaker was created to bring back the legendary tone of Celestion’s 1970s 10" models, delivering a 10" speaker sound with unexpectedly full-bodied character. Though its output is modest, the G10 Greenback carries the substantial low-end presence of a 12" speaker, along with a complex midrange and a smooth vintage-style top end. In small combo amps, it adds a distinctly refined character, and in a 4×10 configuration, it produces a gritty, full-bodied tone with plenty of low-end punch.
  • Nominal diameter: 254mm / 10in
  • Power rating: 30W
  • Rated impedance: 16Ω
  • Sensitivity: 95dB
  • Chassis type: Pressed steel
  • Magnet type: Ceramic
  • Magnet weight: 0.56kg / 20oz
  • Voice coil diameter: 1.75in / 44mm
  • Voice coil material: Round copper
  • Frequency range: 95-5500Hz
  • Resonance frequency, Fs: 98Hz
  • DC resistance, Re: 12.05Ω
  • Cut-out diameter: 229mm / 9in
  • Diameter: 254mm / 10in
  • Magnet structure diameter: 124mm / 4.9in
  • Mounting hole dimensions: 6.5x8.9mm / 0.25x0.35in
  • Mounting hole PCD: 245mm / 9.6in
  • Number of mounting holes: 8
  • Chassis depth (inc gasket): 72mm / 2.83in
  • Magnet depth: 30mm / 1.17in
  • Overall depth: 102mm / 4.0in
  • Unit weight: 1.6kg / 3.5lb
BrandCelestion
ModelG10 Greenback
Part Number294-2252
UPC739894564700
Weight5
Nominal Diameter10"
Power Handling (RMS)30 Watts
Impedance16Ω
