  • B&C DE250-8 1" Polyimide Horn Driver 8 Ohm 2/3-Bolt
B&C SpeakersPart # 294-605
Model: DE250-8
The B&C Speakers DE250 1" HF driver uses its polyimide diaphragm and optimized ferrite motor to great effect. It is a durable, accurate, and great-sounding professional audio transducer.
  • Polyimide diaphragm for smooth and natural response
  • Recommended crossover of 1,600 Hz or higher with 12 dB slope
  • Considered one of the best sounding 1" compression drivers available
  • Extremely high efficiency is perfect for high output systems
  • 1" bolt-on format (2-bolt/3-bolt)
Beyma CD-171Fe/PT 1" Compression Driver 8 Ohm 2/3-Bolt
Price: $124.02Part # 253-126
See all items in Horn Drivers
Your Price: $137.46
Save $91.64 (40%)
We'll send you an email when B&C DE250-8 1" Polyimide Horn Driver 8 Ohm 2/3-Bolt is back in stock or available for preorder.
Order in the next 12 hr 21 min to ship today. Details
B&C's DE250 1" high frequency compression driver features smooth and accurate response. Its low mass polyimide diaphragm and optimized ceramic magnet assembly allow high sensitivity and low distortion up to 18 kHz. Popular with professional users as well as many discriminating "high efficiency" home audio enthusiasts, the B&C Speakers DE250 is considered one of the most listenable high performance 1" HF drivers available.
Specifications: • Power handling: 60 watts RMS/120 watts program above recommended crossover of 1.6 kHz/12 dB slope • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 1,000-18,000 Hz • SPL: 108.5 dB 1W/1m • Dimensions: 4.7" diameter x 2.4" depth • Net weight: 4.6 lb. • Replacement diaphragm available.
BrandB&C Speakers
ModelDE250-8
Part Number294-605
UPC844632001765
Weight5
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt/3-Bolt
Power Handling (RMS)120 Watts
Impedance8Ω
