  • Audtek VC70-R100 70V Rotary Speaker Volume Control 100W
Audtek ElectronicsPart # 300-553
Model: VC70-R100
The Decora Style Volume Control is specifically designed for 70-volt line PA speaker systems, offering a user-friendly interface with 10 levels of attenuation via a reliable detented control. Its compact design fits most standard single-gang electrical junction boxes for straightforward installation.
  • 10 indented attenuation steps from no signal to full signal with no signal quality loss
  • Design for use with any 70V speakers
  • Fits into most deep single gang electrical junction boxes
  • Includes matching white wall plate
  • Speaker wires easily attach to the removable type phoenix terminals before final installation
Your Price: $20.48
MSRP: $34.99
Save $14.51 (41%)
We'll send you an email when Audtek VC70-R100 70V Rotary Speaker Volume Control 100W is back in stock or available for preorder.
Order in the next 2 hr 57 min to ship today. Details
Set the Mood for the Room
Ten Volume Settings
Easy Installation
This model features screw-type connectors that accommodate wire sizes up to 14 AWG, simplifying the setup process. Install the speaker wires into the removable phoenix connector and then plug the connector into the volume control. This makes it so much easier than having to hold the volume control in your hand while you install the wires. With a frequency response ranging from 35 Hz to 20,000 Hz and a power handling capacity of 100W RMS, it ensures high-quality sound performance. The mounting depth is 2 inches and includes a matching wall plate for a seamless finish. It also includes white screws for the wall plate and screws for the single-gang electrical box.
One of the standout benefits of the Audtek VC70-50R-v2 is its independent grounds, which provide remarkable versatility. This means you can confidently connect it to virtually any 70V amplifier without worrying about compatibility issues. This flexibility opens up a world of possibilities for integrating it into your existing setup or while planning a new installation.
This volume control is not only functional but enhances the overall audio experience in any setting.  The included white wall plate whether you're upgrading an existing sound system or installing a new one, this product is the ideal choice for reliable 70V volume management. We encourage you to elevate your audio environment with this efficient and stylish solution!
BrandAudtek Electronics
ModelVC70-R100
Part Number300-553
UPC848864077628
Weight0.79
Control SurfaceRotary Knob
Wall Plate ColorWhite
