  • Front Loading Adjustable Automatic Wire Stripper with Wire Cutter
CLEARANCE Front Loading Adjustable Automatic Wire Stripper with Wire Cutter
Parts ExpressPart # 360-212
Whether you're a professional electrician or a DIY enthusiast, this automatic wire stripper is a must-have addition to your toolkit. Its user-friendly patented design and reliable performance will make your wiring projects quicker and more enjoyable. So why wait? Upgrade your wire stripping experience today and enjoy the convenience and efficiency of this automatic wire stripper.
  • Handles located behind the front-loading jaws for reaching into tight spaces
  • Easy to strip the same amount of insulation, every time
  • Works with single-conductor 10 to 24 AWG stranded or solid wire
  • Easily strip multiple speaker wires in and outside speaker cabinets in seconds
CLEARANCE $12.41
Save $7.58 (38%)
51 In Stock
We'll send you an email when Front Loading Adjustable Automatic Wire Stripper with Wire Cutter is back in stock or available for preorder.
Order in the next 0 hr 42 min to ship today. Details
Gone are the days of fumbling with complicated settings and awkward hand positions. With our wire stripper, all you need to do is set the desired strip length, insert the wire, and effortlessly squeeze the handles. With a strip length range of 7/32" to 3/4" (6 to 18 mm), you have the flexibility to strip wires to the exact length you desire. Say goodbye to guesswork and hello to precise and professional results! It's as simple as that! No more wasted time and energy on tedious manual stripping.
But that's not all! We understand the importance of reaching into tight spaces when working with wires. That's why we've strategically placed the handles behind the jaws of our wire stripper. This innovative design plus front-loading stripping action enables you to effortlessly maneuver and access even the most hard-to-reach areas, saving you valuable time and effort.
Underneath the handle of this incredible tool lies a convenient wire cutter, designed to save you time and money. No longer will you have to waste precious moments searching for another tool to cut your wires. With this all-in-one solution, cut and strip wire gauges from 10 to 24 AWG enabling you to streamline your work and achieve more in less time!
So why settle for anything less when you can have the ultimate wire stripping and cutting solution? Upgrade your toolkit today and experience the convenience and efficiency that this tool brings. Say goodbye to wasted time and unnecessary expenses, and say hello to a more productive and cost-effective way of working.
Part Number360-212
UPC848864074269
Weight0.45
