  • Audtek 100 ft. 16 AWG Stranded OFC Twisted Pair Speaker Cabinet Hookup Wire Blue/Black
Audtek ElectronicsPart # 101-264
Model: TSW-B100
Audtek 2-conductor 16-gauge OFC twisted hook-up wire for better current flow, and interference resistance when building your next audio/speaker project.
  • Twisting action helps cancel out the natural inductance in wires which enhances current flow and reduces interference from adjacent wires and other outside magnetic fields
  • Blue and black wires for easy polarity and speaker identification inside speaker cabinets
  • 26/30-gauge oxygen free copper strands/conductor increases performance versus CCA
  • Prevents loss in current flow so well many alarm speakers and sirens use to produce maximum sound level decibels
  • Total outer diameter 0.19" (4.75 mm) or twist it tighter for more compactness
Your Price: $44.98
MSRP: $89.99
Save $45.01 (50%)
98 In Stock
We'll send you an email when Audtek 100 ft. 16 AWG Stranded OFC Twisted Pair Speaker Cabinet Hookup Wire Blue/Black is back in stock or available for preorder.
Many manufactures and other speaker builders use twisted pair wires inside their cabinets. Twisting action cancels out any natural inductance between the two wires, plus helps reduce magnetic interference from other wires and other sources inside/outside the cabinet. The twisting action reduces interference so well that you see many car amplifier wiring kits use it for running the line output of the head unit to the line input of the amplifier. This enables the Aux cable to use higher gauge wires for better current flow without having to use an outer shield around the cable.
Audtek 16 AWG twisted cable uses 26/30-gauge OFC copper stands to reduce current loss versus CCA stands. Pure copper strands also make it easy to create long lasting soldering joints. The blue and black PVC insulators that surround the strands make it easy to identify polarity, plus it also comes in a red and black insulator (sold separately) to help with speaker identification.
BrandAudtek Electronics
ModelTSW-B100
Part Number101-264
UPC848864070445
Weight2.5
Conductors2 Conductor
Jacket ColorDark Blue
Wire Gauge16
