AtlasIED CLA804 800W 4 Channel Multi Impedance Power Share Amplifier
The Atlas CLA804 is a versatile four-channel, 800-watt amplifier featuring innovative Power Share technology, allowing precise distribution of power across different zones, regardless of load impedance. This flexibility makes it ideal for both commercial distributed systems (25V/70.7V/100V) and low-impedance applications (2, 4, or 8 ohms).
- Each channel can be configured individually to 2Ω, 4Ω, 8Ω, 25V, 70.7V, or 100V
- Global auto-sensing design delivers a stable output even in fluctuating power conditions
- Power share allows each channel to be configured to be 4x200W, 2x350W/50W, 2x300W/100W, or 2x250W/150W
- Quickly switch power configuration via switches located on the rear panel
- Direct-coupled thermal transfer design effectively maintains optimal temperature across all loads and output levels
- Convection cooled with additional whisper-quiet fans when necessary
- 1RU, half-rack design demands little space in your equipment rack
We'll send you an email when AtlasIED CLA804 800W 4 Channel Multi Impedance Power Share Amplifier is back in stock or available for preorder.
