  • Alphasonik ALPHA1K ALPHA Series 1,000 Watt Full-Range Mono Amplifier
CLEARANCE Alphasonik ALPHA1K ALPHA Series 1,000 Watt Full-Range Mono Amplifier
AlphasonikPart # 268-684
Model: ALPHA1K
Achieve unparalleled sound performance with the Alphasonik ALPHA1K ALPHA Series 1,000 Watt Full-Range Mono Amplifier. This powerful and efficient amplifier is engineered to deliver exceptional clarity and volume, providing a superior audio experience. Whether you're looking to enhance your car's audio system or build a new one, the ALPHA1K offers the perfect blend of power, precision, and reliability.
  • Total Power Output: Delivers a solid 1,000 watts of powerful, clear audio.
  • Full-Range Mono Amplifier: Supports a wide range of frequencies for versatile sound reproduction.
  • Class D Technology: Ensures high efficiency and minimal heat generation for long-lasting performance.
  • Variable Low Pass Filter: Allows for precise control over audio frequencies to optimize sound quality.
  • Compact, Rugged Design: Fits easily into most vehicle interiors and is built to withstand daily use.
CLEARANCE $199.95
1 In Stock
We'll send you an email when Alphasonik ALPHA1K ALPHA Series 1,000 Watt Full-Range Mono Amplifier is back in stock or available for preorder.
The Alphasonik ALPHA1K ALPHA Series 1,000 Watt Full-Range Mono Amplifier is designed to deliver powerful and precise audio, making every note and beat sound clear and impactful. With a total power output of 1,000 watts, this amplifier provides the strength needed to drive your audio system, delivering high-quality sound across a wide range of frequencies. Its Class D technology ensures high efficiency, reducing heat generation and extending the life of the amplifier.
Equipped with a variable low pass filter, the ALPHA1K allows you to fine-tune your sound to achieve the best possible audio experience. Whether you're looking to boost the bass or enhance the mid and high frequencies, this amplifier gives you the control needed to optimize your sound. The compact and rugged design ensures that it fits seamlessly into most vehicle interiors, providing a durable and unobtrusive addition to your car audio setup.
Built to last, the Alphasonik ALPHA1K is a reliable and long-lasting solution for anyone seeking to upgrade their car audio system. Experience the power and precision of the Alphasonik ALPHA1K ALPHA Series 1,000 Watt Full-Range Mono Amplifier and enjoy superior sound quality on every drive.
BrandAlphasonik
ModelALPHA1K
Part Number268-684
UPC850009208149
Weight4.2
Input TypeRCA Line Level
Output Channels1
RMS Power Output (4 Ohms)1,000
