  • Alphasonik ALPHA3K ALPHA Series 3,000 Watt Full-Range Mono Amplifier
CLEARANCE Alphasonik ALPHA3K ALPHA Series 3,000 Watt Full-Range Mono Amplifier
AlphasonikPart # 268-688
Model: ALPHA3K
Elevate your car audio experience with the Alphasonik ALPHA3K ALPHA Series 3,000 Watt Full-Range Mono Amplifier. This powerhouse amplifier is engineered to deliver exceptional clarity and high volume, ensuring your music sounds its best. Perfect for serious audiophiles and car audio enthusiasts, the ALPHA3K combines robust power with precision engineering to bring your audio system to life.
  • Impressive Power Output: Delivers a formidable 3,000 watts for superior audio performance.
  • Full-Range Mono Amplifier: Handles a wide range of frequencies for versatile sound reproduction.
  • Class D Technology: Ensures high efficiency and low heat generation, extending the amplifier's life.
  • Variable Low Pass Filter: Allows for precise tuning of audio frequencies to optimize sound quality.
  • Compact and Rugged Design: Fits easily into most vehicle interiors and is built for durability and reliability.
CLEARANCE $399.95
1 In Stock
We'll send you an email when Alphasonik ALPHA3K ALPHA Series 3,000 Watt Full-Range Mono Amplifier is back in stock or available for preorder.
The Alphasonik ALPHA3K ALPHA Series 3,000 Watt Full-Range Mono Amplifier is designed to provide powerful and precise audio, making every detail of your music come alive. With a total power output of 3,000 watts, this amplifier can drive your audio system with ease, delivering high-quality sound across a wide frequency range. Its Class D technology ensures high efficiency, reducing heat buildup and enhancing long-term reliability.
Equipped with a variable low pass filter, the ALPHA3K allows you to fine-tune your sound to achieve the best possible audio experience. Whether you want to emphasize deep bass or clear highs, this amplifier gives you the control needed to tailor your sound to your preferences. The compact and rugged design ensures easy installation in most vehicle interiors, making it a durable and unobtrusive addition to your car audio setup.
Built to last, the Alphasonik ALPHA3K is a reliable and high-performing solution for anyone looking to upgrade their car audio system. Experience the power and precision of the Alphasonik ALPHA3K ALPHA Series 3,000 Watt Full-Range Mono Amplifier and enjoy unparalleled sound quality on every drive.
BrandAlphasonik
ModelALPHA3K
Part Number268-688
UPC850009208170
Weight5.65
Input TypeRCA Line Level
Output Channels1
RMS Power Output (4 Ohms)3000
