  • 3M 1" Clear Heat Shrink Tubing 4 ft.
3MPart # 082-074
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation.
  • Shrinks to half its size
  • Usually used over electrical splices and terminations
  • Split and cold resistant
Your Price: $9.98
MSRP: $14.99
Save $5.01 (33%)
Quantity:Qty: 1-9 $9.98/ea
Quantity:Qty: 10-24 $9.48/ea
Quantity:Qty: 25+ $8.78/ea
We'll send you an email when 3M 1" Clear Heat Shrink Tubing 4 ft. is back in stock or available for preorder.
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation. This tubing is typically used as a shrink-fit electrical insulation over splices and terminations. It is also used for lightweight wire harness covering, wire marking, wire bundling, component packaging and fire resistant covering. The heat shrink tubing is split resistant, mechanically tough, easily marked and resists cold flow. Sold in 4 ft. lengths with header.
All 4-foot lengths of heat shrink tubing is folded for shipping. It may arrive with kinks, but don’t worry. When heat is applied the kinks disappear.
Specifications: • UL Recognized and CSA Certified at 600 volts at 257ºF(125ºC) • UL File No. E-39100 and CSA No. 38227. MIL-I-23053/5, Class 1,2. AMS 3636 (Type I) and AMS 3637 (Type II).
Brand3M
Part Number082-074
UPC051128596821
Weight0.165
Adhesive SealantNo
ColorClear
Nominal Preshrink I.D.1" - 24mm
Shrink Ratio2:1
