  • 3M 1/4" Clear Heat Shrink Tubing 4 ft.
CLEARANCE 3M 1/4" Clear Heat Shrink Tubing 4 ft.
3MPart # 082-038
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation.
1/4" Heat Shrink Tubing 2:1 Thin Wall-Clear 4 ft.
Price: $1.19Part # 080-966
See all items in Heat Shrink Tubing
CLEARANCE $4.98
Save $3.01 (38%)
18 In Stock
We'll send you an email when 3M 1/4" Clear Heat Shrink Tubing 4 ft. is back in stock or available for preorder.
Order in the next 3 hr 57 min to ship today. Details
3M™ heat shrink shrinks to half of its original size (2:1) and offers an outstanding balance of electrical, physical and chemical properties for a wide variety of applications. Rated for 275ºF(135ºC) continuous operation. This tubing is typically used as a shrink-fit electrical insulation over splices and terminations. It is also used for lightweight wire harness covering, wire marking, wire bundling, component packaging and fire resistant covering. The heat shrink tubing is split resistant, mechanically tough, easily marked and resists cold flow. Sold in 4 ft. lengths with header.
All 4-foot lengths of heat shrink tubing is folded for shipping. It may arrive with kinks, but don’t worry. When heat is applied the kinks disappear.
Specifications: • UL Recognized and CSA Certified at 600 volts at 257ºF(125ºC) • UL File No. E-39100 and CSA No. 38227. MIL-I-23053/5, Class 1,2. AMS 3636 (Type I) and AMS 3637 (Type II).
Brand3M
Part Number082-038
UPC00051128596555
Weight0.0264
Adhesive SealantNo
ColorClear
Nominal Preshrink I.D.1/4" - 6mm
Shrink Ratio2:1
