  • Peerless DA25BG08-06 1" Aluminum Dome Tweeter 6 Ohm
Peerless by TymphanyPart # 264-1460
Model: DA25BG08-06
With a low Fs and high efficiency, the Peerless DA25BG08-06 will be at home in any higher efficiency speaker design. This 1" aluminum dome tweeter produces extremely smooth and accurate sound with extraordinary transient response.
  • Low 721 Hz Fs allows crossovers as low as 1,500 Hz, perfect for 2-way designs
  • Large rubber surround minimizes dome resonances within the audible range
  • Powerful motor and light diaphragm results in high efficiency
  • Integrated grill with diffusor protects the dome and improves response
Dayton Audio ND20FA-6 3/4" Soft Dome Neodymium Tweeter
Price: $10.98Part # 275-030
See all items in Tweeters
Your Price: $30.49
MSRP: $44.99
Save $14.50 (32%)
Quantity:Qty: 1-3 $30.49/ea
Quantity:Qty: 4+ $29.03/ea
We'll send you an email when Peerless DA25BG08-06 1" Aluminum Dome Tweeter 6 Ohm is back in stock or available for preorder.
Estimated back in stock 9/12/2025
Delivering high performance at an amazing value, the Peerless DA25BG08-06 is a wonderful choice for high efficiency 2 or 3-way speaker designs. Thanks to the damped 1" aluminum dome and large rubber surround Peerless has managed to drive any dome resonances well outside of the audible frequency range. Also, by using a damped rear chamber the Fs was driven down to 721 Hz for crossover points as low as 1,500 Hz making this tweeter suitable for use in a 2-way with woofers as large as 8". Finally, thanks to Ferrofluid cooling and large ferrite motors helping to wick away heat, power handling is 100 watts RMS giving the DA25BG08-06 extremely high output capabilities.
BrandPeerless by Tymphany
ModelDA25BG08-06
Part Number264-1460
UPC848864044941
Weight1.5
Cone / Dome Diameter1"
Cutout Diameter2.875
Tweeter TypeMetal Dome
Power Handling (RMS)100 Watts
Frequency Response2,000 to 20,000Hz
Sensitivity93.5dB 2.83V/1m
Resonant Frequency (Fs)721Hz
DC Resistance (Re)5.2Ω
Mechanical Q (Qms)1.89
Electromagnetic Q (Qes)0.7
Total Q (Qts)0.51
Overall Outside Diameter4.09"
Depth1.73"
