  • Dayton Audio ND16FA-6 5/8" Soft Dome Neodymium Tweeter
Dayton AudioPart # 275-025
Model: ND16FA-6
Don't let the low price fool you! This versatile tweeter is a huge step above the average "budget" tweeter.
  • Unique front pressfit, flush-mount design
  • Center-to-center spacing as low as 1-3/8"
  • Extended response with superior off-axis dispersion
  • Compact neodymium motor is effectively self-shielded
  • Ferrofluid enhances power handling and helps damp resonance
  • Great replacement for car door tweeters
Dayton Audio ND16FA-4 5/8" Soft Dome Neodymium Tweeter 4 Ohm
Price: $8.98Part # 275-106
See all items in Tweeters
Your Price: $8.98
Save $3.01 (25%)
We'll send you an email when Dayton Audio ND16FA-6 5/8" Soft Dome Neodymium Tweeter is back in stock or available for preorder.
Don't let the low price fool you! This versatile tweeter is a huge step above the average "budget" tweeter. Conceived with line array thoughts in mind, it is finally possible to achieve the inter-driver spacing needed to minimize comb filtering out to nearly 20 kHz. But their uses don't stop at line arrays-- they have the sensitivity, smoothness, and power handling to individually do a two-way with most small woofers. Give them a try for your next budget or micro speaker-- you will be pleasantly surprised!
ModelND16FA-6
Part Number275-025
UPC844632056499
Weight0.08
Cone / Dome Diameter0.625"
Cutout Diameter1.28
Tweeter TypeSoft Dome
Power Handling (RMS)10 Watts
Frequency Response3,500 to 27,000Hz
Sensitivity88dB 2.83V/1m
Resonant Frequency (Fs)2125Hz
DC Resistance (Re)5.8Ω
Voice Coil Inductance (Le)0.04mH
Mechanical Q (Qms)3.45
Electromagnetic Q (Qes)6.09
Total Q (Qts)2.2
Overall Outside Diameter1.28"
Depth0.57"
