Wavecor WF275BD01 10-3/4" Paper Cone Woofer 4 Ohm
The WF275BD01 was developed as a high-performance bass and midrange driver for monitors and premium hi-fi loudspeakers. It delivers remarkable low-frequency extension along with dynamic and detailed sound reproduction. Ideal for multi-way systems, it also provides designers the uncommon option of creating 10″ 2-way designs when paired with a compatible tweeter, such as Wavecor 30 mm models.
- Balanced Drive motor structure provides symmetric drive force, significantly lowering even-order harmonic distortion
- New paper/glass fiber cone offers enhanced material consistency and improved stability
- Die-cast aluminum chassis with extensive venting minimizes airflow speed and reduces audible distortion
- Vented voice coil former decreases distortion and limits dynamic compression
- Integrated aluminum field-stabilizing ring reduces high-level distortion
- Black-plated motor components enhance heat dissipation
- Gold-plated terminals support reliable, long-lasting connections
We'll send you an email when Wavecor WF275BD01 10-3/4" Paper Cone Woofer 4 Ohm is back in stock or available for preorder.
