  • Wavecor WF223BD01 8-3/4" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer 4 Ohm
WavecorPart # 298-1212
Model: WF223BD01
The Wavecor WF223BD01 is an 8-3/4" paper/glass fiber cone midwoofer that utilizes balanced drive technology and is designed for demanding bass and midrange applications. The WF223BD01 is a very good choices for either 2 or 3-way speaker systems.
  • Vented voice coil former for reduced distortion and compression
  • Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced 2nd order harmonic distortion
  • Built-in aluminum field-stabilizing ring for reduced high-level distortion
  • Large motor structure for better control and power handling
  • Copper cap on center pole to reduce voice coil inductance and to minimize variations in voice coil inductance as a function of voice coil position
  • New vented chassis for lower air flow speed reducing audible distortion
  • Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
Your Price: $205.00
We'll send you an email when Wavecor WF223BD01 8-3/4" Balanced Drive Paper/Glass Fiber Cone Mid-Woofer 4 Ohm is back in stock or available for preorder.
Estimated back in stock 2/7/2027
The Wavecor WF223BD01 is an 8-3/4" paper/glass fiber cone midwoofer that is designed for demanding bass and midrange applications. This driver is powered by a large magnet structure that ensures good efficiency. The WF223BD01 is a very good choices for 2-way speaker systems or even as midrange in 3-way systems.
The large motor system with 1-1/2" voice coil diameter and large magnet for better control, power handling, and efficiency. The optimized paper/glass fiber cone ensures wide bandwidth and low distortion. Distortion is further reduced by efficient venting of the chassis and voice coil former.
BrandWavecor
ModelWF223BD01
Part Number298-1212
UPC848864055077
Weight6.85
Nominal Diameter8"
Power Handling (RMS)300 Watts
Impedance4Ω
Frequency Response32 to 2,000Hz
Sensitivity89.5dB 2.83V/1m
Voice Coil Diameter1.54"
Resonant Frequency (Fs)32.6Hz
DC Resistance (Re)3.4Ω
Voice Coil Inductance (Le)0.13mH
Mechanical Q (Qms)14.5
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)1.59ft³
Mechanical Compliance of Suspension (Cms)0.7mm/N
BL Product (BL)7.7T·m
Diaphragm Mass Inc. Airload (Mms)34g
Maximum Linear Excursion (Xmax)6.5mm
Surface Area of Cone (Sd)213cm²
Voice Coil FormerFiberglass
Overall Outside Diameter8.80"
Baffle Cutout Diameter7.52"
Depth3.78"
# Mounting Holes6
Sealed Volume0.5ft³
Sealed F366.4Hz
Vented Volume1.25ft³
Vented F335.5Hz
