NEW Wavecor WF211PA01 8-1/4" Paper Cone Woofer 4 Ohm
The 8.25″ WF211PA01 transducer was purpose-built for use in Public Address systems. It combines the renowned audiophile-grade sound of a typical Wavecor driver with the essential traits of PA speakers, including high sensitivity, strong power handling, low distortion, and accurate sound reproduction true to the source.
- Balanced Drive motor structure promotes symmetrical drive force, significantly reducing even-order harmonic distortion
- Oversized motor with 2.5″ voice coil diameter enhances control and power handling
- Robust die-cast aluminum chassis with ample venting lowers airflow speed and reduces audible distortion
- Vented voice coil former minimizes distortion and thermal compression
- Reinforced black fiberglass voice coil former reduces mechanical loss for better dynamics and fine detail retrieval
- Black-plated motor parts optimize heat dissipation to the surrounding environment
- Durable CONEX spider offers long-term mechanical stability and withstands harsh operating conditions
We'll send you an email when Wavecor WF211PA01 8-1/4" Paper Cone Woofer 4 Ohm is back in stock or available for preorder.
