  • Wavecor WF120BD11 4-3/4" Kevlar/Carbon Fiber Cone Midwoofer 4 Ohm
WavecorPart # 298-1227
Model: WF120BD11
The 4.75″ WF120BD11 transducer was developed as a high-performance bass and midrange driver for compact monitor speakers and premium hi-fi systems.
  • New cone made of interwoven Kevlar and Carbon fibers combines low mass, high rigidity, and effective damping for ideal midrange performance
  • Inverted and vented center dome design minimizes compression
  • Sturdy die-cast aluminum chassis with extensive venting reduces airflow speed and cuts audible distortion
  • Black fiberglass voice coil former minimizes mechanical losses for improved dynamics and detail resolution
  • Integrated aluminum field-stabilizing ring reduces distortion at higher output levels
  • Conex spider increases durability under demanding conditions
  • Gold-plated terminals provide a reliable, long-lasting electrical connection
Your Price: $117.00
We'll send you an email when Wavecor WF120BD11 4-3/4" Kevlar/Carbon Fiber Cone Midwoofer 4 Ohm is back in stock or available for preorder.
The WF120BD11 introduces a newly developed cone made of interwoven Kevlar and carbon fibers, combining low mass with exceptional rigidity and internal damping—traits that significantly enhance clarity and accuracy in the midrange. Its Balanced Drive motor structure delivers symmetrical force across the coil’s travel, dramatically reducing even-order harmonic distortion. A vented, inverted center dome minimizes compression, while a copper cap on the center pole reduces voice coil inductance and stabilizes it across excursion for smoother frequency response. The large 1" voice coil is wound on a black fiberglass former to lower mechanical losses, supported by a rigid die-cast aluminum chassis with extensive venting to maintain low air flow speeds and reduce audible distortion. To maintain fidelity at high levels, the motor incorporates an aluminum field-stabilizing ring and thermally optimized black-coated components, while a low-loss suspension and CONEX spider preserve dynamic response and durability over time. Gold-plated terminals complete the design with long-term connection reliability.
Measuring conditions, SPL
Driver mounting: Flush in infinite baffle, back side open (no cabinet)
Microphone distance: 1.0 m
Input signal: 2.83 VRMS LogChirp, 64k, Hanning/2
Smoothing: 1/6 oct.
Measuring conditions, impedance
Driver mounting: Free air, no baffle, back side open (no cabinet)
Input signal: Stepped sine wave, semi-current-drive, nominal current 2 mA
Smoothing: None
Measuring conditions, harmonic distortion
Driver mounting: In sealed enclosure, internal volume 2 lit.
Microphone distance: 0.5 m
Input signal: Stepped sine wave, 4.7 VRMS
Smoothing: 1/12 oct.
BrandWavecor
ModelWF120BD11
Part Number298-1227
UPC848864081120
Weight2.65
Nominal Diameter4-3/4"
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Impedance4Ω
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)56.5Hz
Mechanical Q (Qms)9.4
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)0.14ft³
Mechanical Compliance of Suspension (Cms)1.2mm/N
Diaphragm Mass Inc. Airload (Mms)6.6g
Surface Area of Cone (Sd)48cm²
Cone MaterialCarbon Fiber / Kevlar
Voice Coil FormerFiberglass
Overall Outside Diameter4.72"
Baffle Cutout Diameter3.54"
Depth2.52"
