  • Wavecor WF095WA01 3-3/4" Paper Cone Midwoofer 4 Ohm
WavecorPart # 298-1225
Model: WF095WA01
The WF095WA01 was specifically developed for compact multimedia and lifestyle speaker systems, where space is limited but sound quality must remain uncompromised. Utilizing a stamped steel frame, it delivers excellent performance while keeping production costs low.
  • Vented voice coil former and magnet center pole help lower distortion and compression
  • Vented chassis reduces air flow speed, minimizing audible distortion
  • Low-loss suspension with high Qm improves detail retrieval and dynamic accuracy
  • Black-coated magnet components enhance heat dissipation for better power handling
  • Progressive suspension with CONEX spider offers long-lasting durability in demanding conditions
  • Gold plated terminals resist oxidation to ensure a reliable long-term connection
  • Comes with foam gasket pre-attached for easy installation and secure cabinet sealing
Dayton Audio PC83-4 3" Full-Range Poly Cone Driver
Price: $15.49Part # 295-154
Your Price: $55.00
We'll send you an email when Wavecor WF095WA01 3-3/4" Paper Cone Midwoofer 4 Ohm is back in stock or available for preorder.
The WF095WA01 is engineered for high-performance sound reproduction with a vented voice coil former and center pole that work together to reduce distortion and compression during demanding playback. Its vented chassis design lowers air flow speed, minimizing turbulence-related noise and preserving detail. The voice coil is wound with copper-clad aluminum wire to improve efficiency and enhance dynamic response, while the heavy-duty black fiberglass bobbin boosts power handling and reduces mechanical losses for clearer low-level detail. A low-loss suspension system with high mechanical Q delivers better transient accuracy, supported by a progressive CONEX spider designed for durability even under extreme conditions. Additional features include black-coated magnet components for improved thermal conductivity, gold-plated terminals for reliable, corrosion-resistant connections, and a pre-attached foam gasket that simplifies mounting while ensuring a tight acoustic seal.
Measuring conditions, SPL
Driver mounting: Flush in infinite baffle, back side open (no cabinet)
Microphone distance: 1.0 m
Input signal: 2.83 VRMS LogChirp, 64k, Hanning/2
Smoothing: 1/6 oct.
Measuring conditions, impedance
Driver mounting: Free air, no baffle, back side open (no cabinet)
Input signal: Stepped sine wave, semi-current-drive, nominal current 2 mA
Smoothing: None
Measuring conditions, harmonic distortion
Driver mounting: In sealed enclosure, internal volume 1 lit.
Microphone distance: 0.5 m
Input signal: Stepped sine wave, 2.0 V
Smoothing: 1/12 oct.
BrandWavecor
ModelWF095WA01
Part Number298-1225
UPC848864081106
Weight1.2
Nominal Diameter3-3/4"
Power Handling (RMS)10 Watts
Power Handling (MAX)25 Watts
Impedance4Ω
Sensitivity86.5dB 2.83V/1m
Voice Coil Diameter0.87"
Resonant Frequency (Fs)86Hz
Mechanical Q (Qms)6.6
Electromagnetic Q (Qes)0.69
Total Q (Qts)0.62
Compliance Equivalent Volume (Vas)0.06ft³
Mechanical Compliance of Suspension (Cms)0.94mm/N
BL Product (BL)3T·m
Diaphragm Mass Inc. Airload (Mms)3.6g
Maximum Linear Excursion (Xmax)2.7mm
Surface Area of Cone (Sd)35cm²
Cone MaterialPaper
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter3.74"
Baffle Cutout Diameter2.76"
Depth1.65"
