  • Visaton TIW200XS8 8" High-End Woofer 8 Ohm
CLEARANCE Visaton TIW200XS8 8" High-End Woofer 8 Ohm
VisatonPart # 292-7809
Model: TIW 200 XS
The Visaton TIW 200 XS is a premium 20 cm (8") woofer designed for exceptional low-frequency reproduction, ideal for compact subwoofer systems. With a robust design and advanced materials, it is perfect for applications requiring deep, precise bass and high efficiency. Its unique diaphragm and venting mechanisms make it an outstanding choice for audiophiles and speaker builders.
  • Frequency response up to 7,500 Hz for wide-range sound reproduction
  • Mean sound pressure level of 84 dB (1 W/1 m) for efficient output
  • Resonance frequency at 30 Hz for deep bass performance
  • Excursion limit of ±12.5 mm allowing significant diaphragm movement
  • Effective piston area of 206 cm² contributing to substantial sound pressure
Visaton AL200-8 8" Aluminum Cone Woofer 8 Ohm
Price: $238.94Part # 292-7805
Visaton GF200-2x4 8" DVC Woofer 2x4 Ohm
Price: $189.35Part # 292-7808
See all items in Woofers
We'll send you an email when Visaton TIW200XS8 8" High-End Woofer 8 Ohm is back in stock or available for preorder.
The TIW 200 XS features a fiberglass and polyester fabric sandwich diaphragm, offering enhanced rigidity and minimized resonance for accurate sound reproduction even under demanding conditions. Its extra-wide cone and long voice coil, combined with a substantial magnet system, enable significant excursion for powerful, distortion-free bass. Advanced venting, including a pole piece hole, cutouts in the pole plate, and an aluminum die-cast basket, ensures minimal airflow noise and improved efficiency. Capable of handling up to 180 watts, this woofer is engineered for reliability and longevity. It integrates seamlessly into various cabinet designs, supporting volumes from 20 to 50 liters, with tuning frequencies between 31 Hz and 52 Hz in bass reflex setups. The TIW 200 XS delivers exceptional performance, offering flexibility and precision for custom subwoofer systems that demand high fidelity and deep bass response.
Technical Data
  • Rated power: 120 W
  • Maximum power: 180 W
  • Nominal impedance Z: 8 Ohm
  • Frequency response: fu–7500 Hz
    (fu: Lower cut-off frequency depending on cabinet)
  • Mean sound pressure level: 84 dB (1 W/1 m)
  • Opening angle (-6 dB): 48°/4000 Hz
  • Excursion limit: ±12.5 mm
  • Resonance frequency fs: 30 Hz
  • Magnetic induction: 1.1 T
  • Magnetic flux: 1050 µWb
  • Height of front pole-plate: 8 mm
  • Voice coil diameter: 38 mm
  • Height of winding: 30 mm
  • Cutout diameter: 190 mm
  • Net weight: 3.5 kg
  • D.C. resistance Rdc: 6 Ohm
  • Mechanical Q factor Qms: 5.19
  • Electrical Q factor Qes: 0.5
  • Total Q factor Qts: 0.46
  • Equivalent Volume Vas: 51.5 l
  • Effective piston area Sd: 206 cm²
  • Dynamically moved mass Mms: 33 g
  • Force factor Bxl: 8.51 Tm
  • Inductance of the voice coil L: 1.6 mH
  • Connections: 4.8 x 0.8 mm (+)/2.8 x 0.8 mm (-)
BrandVisaton
ModelTIW 200 XS
Part Number292-7809
Weight10
Nominal Diameter8"
Power Handling (RMS)120 Watts
Power Handling (MAX)180 Watts
Sensitivity84dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)30Hz
DC Resistance (Re)
Voice Coil Inductance (Le)1.6mH
Mechanical Q (Qms)5.19
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)1.82ft³
BL Product (BL)8.51T·m
Diaphragm Mass Inc. Airload (Mms)33g
Maximum Linear Excursion (Xmax)12.5mm
Surface Area of Cone (Sd)206cm²
Cone MaterialAluminum
# Mounting Holes6
