  • Visaton AL200-8 8" Aluminum Cone Woofer 8 Ohm
VisatonPart # 292-7805
Model: AL 200
The Visaton AL 200 is a high-end 20 cm (8") woofer designed for audiophiles seeking precise and dynamic low-frequency performance. Its stiff aluminum cone, solid die-cast basket, and elastic rubber surround ensure durability and exceptional sound quality. The vented pole plate, damper, and Kapton voice coil carrier minimize mechanical and electrical losses, resulting in a fast pulse response ideal for both 2-way and 3-way high-end speaker systems.
  • Frequency response from 32 Hz to 9,000 Hz for wide-range sound reproduction
  • Resonance frequency at 32 Hz for deep bass performance
  • Maximum power handling of 180 W for robust performance
  • Excursion limit of ±10 mm allowing significant diaphragm movement
  • Effective piston area of 216 cm² contributing to substantial sound pressure
Visaton GF200-2x4 8" DVC Woofer 2x4 Ohm
Price: $189.35Part # 292-7808
See all items in Woofers
Your Price: $238.94
We'll send you an email when Visaton AL200-8 8" Aluminum Cone Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 7 hr 24 min to ship today. Details
The AL 200's lightweight aluminum cone ensures a fast pulse response, making it suitable for high-fidelity audio applications. Its design allows for integration into various cabinet sizes, with recommended volumes ranging from 30 liters to 70 liters in bass reflex configurations, achieving tuning frequencies between 27 Hz and 40 Hz. This versatility makes the AL 200 an excellent choice for audiophiles and speaker builders aiming for superior low-frequency performance in their custom speaker designs.
Technical Data
  • Rated Power: 120W
  • Maximum Power: 180W
  • Nominal impedance: 8 Ohm
  • Frequency response: fu-30000 Hz
    (fu: Lower cut-off frequency depending on cabinet)
  • Mean sound pressure level: 88 dB (1 W/1 m)
  • Opening angle: (-6 dB) 122°/4000 Hz
  • Excursion Limit: +/−10 mm
  • Resonance frequency fs: 32 Hz
  • Magnetic induction: 1.3 T
  • Magnetic flux: 930 µWb
  • Height of front pole-plate: 6 mm
  • Voice coil diameter: 38 mm
  • Height of winding: 20 mm
  • Cutout diameter: 190 mm
  • Net weight: 2.5 kg
  • D.C. resistance Rdc: 6.6 Ohm
  • Mechanical Q factor Qms: 3.73
  • Electrical Q factor Qes: 0.39
  • Total Q factor Qts: 0.35
  • Effective volume Vas: 77 l
  • Effective piston area Sd: 216 cm²
  • Dynamically moved mass Mms: 21 g
  • Inductance of the voice coil L: 1.2 mH
  • Connections: 4.8 x 0.8 mm (+)/2.8 x 0.8 mm (-)
BrandVisaton
ModelAL 200
Part Number292-7805
Weight4
Nominal Diameter8"
Power Handling (RMS)120 Watts
Power Handling (MAX)180 Watts
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1.496"
Resonant Frequency (Fs)32Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)1.2mH
Mechanical Q (Qms)3.73
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)2.72ft³
BL Product (BL)8.8T·m
Diaphragm Mass Inc. Airload (Mms)21g
Maximum Linear Excursion (Xmax)10mm
Surface Area of Cone (Sd)216cm²
Cone MaterialAluminum
Overall Outside Diameter8.74"
Depth3.5"
# Mounting Holes6
